#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
That is exactly how your oil gets dirty. Particles get through the air filter and past the piston rings. Do some reading on this and you will see. Why else do they tell you to change more frequently if you are in a dusty environment?
#16 | |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Agreed!!
#17 |
![]() Drives: 2014 Subaru Forester, 2010 Equinox Join Date: Nov 2011
I have always been told 5,000 miles is perfectly fine on a car that runs well with no problems. If it is a car that needs a little TLC often, you should probably change oil at 3,000.
#18 |
Future Camaro Owner
Drives: 2010 Jeep Wrangler Sahara 4dr Join Date: Aug 2006
I do every 5k in my Jeep, but when I had my G8 GT it was every 12k...but it held 8.75 quarts.
#19 |
![]() ![]() ![]() ![]() Drives: 2012 2LT/RS Join Date: Oct 2011
I've worked with the engineer who supported IT at Mobil-1's research center, where they developed Mobil-1. He asked them questions all the time, they loved that he was a carbuff. The tests they ran showed that even after 10,000 miles the viscosity in Mobil-1 was close to original. Not so with non-syn oil, not even close. Of course, the oil still gets dirty so you need to change the filter to at least remove grit. They said acids are better "controlled" with Mobil-1, though I'm unsure what that meant - assumed somehow that Mobil-1 didn't go as acidic, or as quickly, as non-syn oils.
Anyway, because of this feedback I had started to just change my filter at 3k and full load at 9k. I did this on 4 different cars, 2 Toyota MR2's (which I constantly shifted at redline) and 2 different turbocharged Volvo's, one I sold with 285k miles, the other with 225k. "No oil related issues ever", but does that mean there would never be? Dunno...but these cars did not have an easy life, trust me. |
#20 | |
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: the 2nd amendment home Join Date: May 2008
12.6 litre Detroit diesel holds 10 gallons of dino oil, company changes filter ~15,000 miles and complete oil change ~30,000 miles. It now has 570,000 miles, still runs strong and has never used a gallon of oil between changes. Impressive...
-- Benjamin Franklin lib·er·ty /ˈlibərdē/ noun 1. the state of being free within society from oppressive restrictions imposed by authority on one's way of life, behavior, or political views |
#22 |
Okie doke
I'd say it all depends on how you drive and where you live as well ... Oil changes are pretty cheap insurance but I'd go for every 5k with full synthetic ... This is what Ford recommends ..
Crowley
#23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
The problem I see with this very long "recommended" miles and intervals is the marketing aspect. I think its worse with these, than with the 3K recommendation.
Take a close look at the first post, which defines "severe". Once a week in stop and go? Idleing? Short trips? Over 90 degrees outside? This is considered "severe"? I don't know about you guys, but a lot of it sounds pretty "normal" to me. If not experiencing any of these "severe" conditions is nescessary for the oil to get its maximum "life", sounds like pie-in-the sky to me. I think the 3K guys still have it right. Last edited by 90503; 04-23-2012 at 03:44 PM. |
#24 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Where you run into trouble is when you go an extended peroid without an oil change and you have failed to check the oil level. You get down a few quarts (or more) and the remaining oil overheats and breaks down, or worse you loose oil pressure because there is not enough in the pan.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
#25 | |
Dumping full synthetic @ 3000 is a waste. Do an extended service and have an oil analysis done, THAT'S cheap insurance and very informative.
I would reduce interval on a modified engine, the more it's modded, the lower the interval. Quote:
#26 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 IBM 1SS (Former) Join Date: Feb 2009
This. Changing every 3K miles is worthwhile insurance the same way it would be worth it to buy insurance against your house being destroyed by a dinosaur. |
#27 |
![]() Drives: Black 2SS/RS LS3 Join Date: Feb 2010
VW`s and porsche`s will have had the sump changed out nearly twice by 10,000 miles just by adding a gallon every 1000 miles
#28 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2005 STi corn fed Join Date: Jul 2008
Hmm, seems like a very generalized opinion. Some engines SHOULD have the oil changed at 3k. My m1 5w30 is sheered to hell after 3k.
| Thread | Thread Starter | Forum | Replies | Last Post |
| 8500 mile oil change interval (5w-30) oil (not synthetic oil) | 2001ragtop | General Automotive + Other Cars Discussion | 0 | 01-18-2012 09:06 AM |
| Okay to use ramps on V6 for oil change? | philipdistefano | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 10 | 01-19-2010 03:05 PM |
| Ok so had the car for a week... Where are you putting your spare change?! | JDBeck23 | 5th Gen Camaro SS LS LT General Discussions | 49 | 10-08-2009 03:05 AM |
| Too late to change at event 3000 ? | scottc | Camaro Price | Ordering | Tracking | Dealers Discussions | 10 | 08-03-2009 05:20 PM |
| ORDER CHANGE @ 1100 | Autobot | Camaro Price | Ordering | Tracking | Dealers Discussions | 4 | 07-24-2009 10:21 AM |
