11-04-2021, 04:12 PM | #15 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
What is the part number for the Performance Copper Free Brake pads for the ZL1?
#SAVETHEMANUALS
11-04-2021, 05:11 PM | #16 |
Drives: 22 Camaro ZLE Join Date: Nov 2021
I have no idea, just saying I was told a similar line about them being the Cadillac CT5-V blackwing standard brakes (which are copper free). I looked for replacement parts for it to see if I could find the part number, but I had no luck. after seeing this thread it feels like its a $500 roll of the dice... could be better / could be worse. Im hoping they aren't worse, but the more I think about it, everything mandatory for Cali is rarely a performance improvement...
2022 Camaro ZL1 1LE
Built 12/7/2021 |
11-05-2021, 09:30 AM | #17 | |
#SAVETHEMANUALS
01-28-2022, 11:41 PM | #18 |
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
So digging up this older thread because I'm looking at a ZL1 from out of state and when I asked the dealer if the car was California smog compliant he got confused and thought I was talking about the brake pads. I immediately told him no they fixed that, forgetting I was speaking to an out of state dealer. When I hung up thought to myself, shit! He's right.
So question, I read the faqs on the pdf that was posted and it wasn't immediately clear to me if it was just a different brake pad. The article mentioned it included different rotors and caliper size but others have mentioned it may be for the lower models. I do all my own brake maintenance and would be fine ordering direct from that dealer or using a different address to order parts but seems like a hassle in the future and or issues if I need warranty work to the system. Thoughts? The price is much better than I'm getting here but I don't want to deal with a ton of bs since it would not be a copper free system on the RPO. |
01-29-2022, 07:35 AM | #19 |
Drives: '22 Summit White ZL1 A10 Join Date: Aug 2019
I still say "pads only" on a ZL1.......
2022 ZL1 Summit White A10
2020 GT350 Heritage Edition-Chassis L0350 2019 ZL1 Summit White M6 2018 Hellcat White Knuckle M6 2016 Hellcat GoMango A8 2002 Dodge Viper Viper Red 2002 Corvette Z06 Millennium Yellow 1998 Dodge Viper Viper Silver Metallic Last edited by Firecaptain; 01-29-2022 at 07:48 AM. |
01-29-2022, 10:42 AM | #20 |
01-29-2022, 12:47 PM | #21 | ||
copper free brakes rotors: GM Genuine Parts Front Disc Brake Rotor #85137534 Outside Diameter 15.67 in / 397.99 mm Regular ZL1 brake rotors: GM Genuine Parts Front Disc Brake Rotor #84271643 (177-1247) Outside Diameter 15.36 in / 390.2 mm Also, calipers are slightly different as well, RUQWIKR noted this in the Apex wheel thread: Quote:
2022 Camaro ZL1 1LE
Built 12/7/2021 |
01-29-2022, 01:02 PM | #22 | |
01-29-2022, 03:15 PM | #23 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Don't sweat it you can get what you need.
01-29-2022, 03:19 PM | #24 |
01-29-2022, 03:31 PM | #25 | |
Drives: 22 ZLE M6 Join Date: Jul 2014
01-29-2022, 09:02 PM | #26 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
There have already been cars delivered with the option. It's the Blackwing front rotor. 398mm.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
01-30-2022, 09:46 PM | #27 |
So I've read that all copper pads are supposed to be reduced down to .5 vs 5% by 2025. Seeing as how copper free setups were sized up to compensate, do you feel the performance would be dramatically hindered if you have the o.g. setup vs the larger copper free?
I'm only familiar with Wilwood who allow me to select different compounds to suit my needs; does Brembo offer different compounds for ZL1s? |
02-01-2022, 07:39 AM | #28 |
I do wonder if the ZL1 'Copper Free' brake pad compound in the same as the CT5V Blackwing.
If GM went into all that effort for brake development (800 hard laps at VIR)..as it had to be copper free....I'd like to think the ZL1 Performance Copper free pads are the same. Same factory for both cars and all....
#SAVETHEMANUALS
