09-21-2017, 05:36 AM | #15 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
My original battery failed last year. Replaced it with OEM AC Delco. From my sources, it was only $18 higher than parts stores' batteries.
01-22-2019, 09:44 AM | #16 |
Battery replacement
Is it crazy that with this really cold weather we have been having recently in NJ, my battery is starting to go? It was the original one that came with the car back in 2010 when I bought it but haven’t had any issues until a few days ago. Guess it’s time! It’s my daily driver too!
01-26-2019, 05:23 PM | #17 |
I just replaced my OEM battery this past monday . 7 years for the original battery is really good .
Anyone know what the charging range is for the battery. My old battery was charging at 14.4v's the new on is charging at 15.3.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
01-26-2019, 08:16 PM | #18 | |
Drives: Miss Con Ception Join Date: Aug 2016
That's okay. I see that on mine sometimes. More often when the HVAC fan is on high, lights, rear defroster... It might also be topping off the battery if it's been on the shelf for a while. You should have ~13.2V when the key is on, car not running, no accessories.
2011 1SS/RS LS3 CGM
01-27-2019, 05:22 AM | #19 |
In vehicles with batteries in the trunk or in the passenger compartment, batteries seem to last longer. I believe that shelter from the heat in the engine compartment helps.
01-27-2019, 06:13 AM | #20 |
Drives: 2010 Camaro 2SS LS3 6 speed IOM/IOM Join Date: Apr 2010
Somehow, I’m still on my original battery on my 2010!
01-28-2019, 09:04 AM | #21 |
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300 Join Date: Nov 2011
Good to hear I still have my original 2012 battery. 25 degrees this morning started straight up and it had been sitting for almost a week.
02-11-2019, 09:37 PM | #22 |
Drives: 2010 2SS/RS LS3 A6 IOM Join Date: May 2013
My original gave out this AM, soooooooooo disappointed.
04-26-2019, 09:13 AM | #23 |
Drives: 2SS/RS IOM 6SP CGRS #9761 Join Date: Mar 2007
My 2010 is 10 years old next month. OEM battery finally gave up. Car only has 22k and sits for long periods of time with no trickle charge. Super impressed!
04-27-2019, 03:27 PM | #24 |
09-02-2019, 08:04 AM | #25 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
My build date is 2009 on my 2010 SS.
Up to 2017, it mostly sat garaged with no battery tender and only had 16k miles on the clock. Now it gets driven more and has 51k miles. It's just now showing signs of getting weak. It's starting slower and on crank, stability link flashed yesterday. AC on, radiator fans are running slower than normal causing the engine to get hot sitting in traffic. But... Very impressed with the life of the OEM battery and will replace with another GM battery,
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
10-01-2019, 09:18 PM | #26 |
Drives: 2015 Supercharged Camaro 1LE Join Date: Mar 2018
where are you buying the OEM batteries ? I imagine if I go to the local dealer it will be quite expensive
Magnuson Supercharged 2015 1LE RS/2SS. Texas Speed Stage 3 Blower Cam. DSX Aux Pump. e85 Flex Fuel Kit. BMR Suspension. On Instagram @wakeyourneighbors @Blown1LE
10-01-2019, 10:42 PM | #27 | |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
nice unit here https://www.amazon.com/Delphi-BU9094...Z66HN8DXZA9WMV |
10-05-2019, 11:54 AM | #28 |
Drives: 2010 Camaro SS! Join Date: May 2009
Still on my original battery....car build date is 4/15/2009, so it's over 10 years old. Only 66k miles, but it's a daily driver here in Colorado. Probably the lower temperatures and low humidity help, but I'm super impressed with it. Starts right up, and is still pretty strong. Will probably replace it with a AC Delco when it finally does go bad.
1SS ABM Manual, Black int., 20" PAWs, Sunroof
$$ down on dealer car #3466, pending Pw: 6-10-2009 Car Picked up by Shipper: 6-22-2009 Car has ARRIVED: 6-24-2009 (and she's a beauty!) |
