Old 05-24-2024, 08:47 AM   #15
sklippi2018
sklippi2018's Avatar
Drives: 2023 Camaro SS 1LE
Originally Posted by keep_hope_alive View Post
I don't think it makes a lot of sense to spend $50k on a car then try to find the cheapest way to make it drive differently. You're ready to reduce fuel economy with $4.50/gal premium fuel prices, so $200 shouldn't be a lot of money. Just wait until you're buying 10 qts of 0W-40 Supercar every 5k miles.
We know the Range module works well, is supported well, and is compatible with the 2023 model.
I wouldn't trust anything random off Amazon that is a Chinese clone. It may be fine for a mid 2000's Silverado, but I wouldn't cheap out in a new car under warranty.
Definitely agree with not cheaping out after dishing out $50+K. Range is having a Memorial Day sale so went ahead and picked one up.
sklippi2018 is offline   Reply With Quote
Old 05-24-2024, 12:58 PM   #16
FH212
FH212's Avatar
Drives: 2021 Camaro SS 1LE
Agree 100% with this! Why cheap out? My Range had worked flawlessly in the limited driving of my Camaro I do and it works.
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot
2001 Mecham Trans Am #3 - 7.0L LS1
FH212 is offline   Reply With Quote
Old 05-26-2024, 12:13 PM   #17
GroundhogSS
GroundhogSS's Avatar
Don't forget. If you need the Range updated to the newest software, you can send it in and they will do it for free. Only costs you shipping, both ways.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
Old 05-26-2024, 02:50 PM   #18
RIPws6
RIPws6's Avatar
Drives: 2019 2SS Riverside Blue
Good info…and just to add to that:
To check your software version just count the number of blinks you get when plugging it in.
I just got mine a month ago and I have version 8.X.
So I get 8 blinks.
FYI.
RIPws6 is offline   Reply With Quote
Old 05-28-2024, 09:39 AM   #19
Mike_Honcho
Drives: camaro
I purchased a refurbished range disabler it was a little cheaper, works fine.
Mike_Honcho is offline   Reply With Quote
Old 05-31-2024, 05:52 PM   #20
sklippi2018
Dumb question but for those who've received their Range did it come in the box sealed (taped shut)? Mine came in today and although still in the mail packaging the box was open.
Thoughts?
Old 05-31-2024, 08:48 PM   #21
RIPws6
RIPws6's Avatar
Mine was not sealed and there was zero documentation.
Old 05-31-2024, 09:29 PM   #22
sklippi2018
Thanks.
Old 05-31-2024, 11:21 PM   #23
RIPws6
RIPws6's Avatar
Originally Posted by sklippi2018 View Post
Thanks.
You’re welcome.
Btw..while im not knocking the folks at Range I just figured a purchase over $100 would be sealed someway and some type of simple instruction sheet.
All of the information is on their website, though. But I do think it would be helpful. If some of the little things were messaged to the buyer via some type of information sheet. For example, a lot of people don’t know how to check their version number. A lot of people don’t know they can’t plug the device in before you start the car or you shouldn’t unplug it while the car is running. Some of those types of things.
Old 06-01-2024, 11:08 AM   #24
flobb
Drives: 2022 2SS
I think you have a typo there. You do plug it in before you start the car. They also say it should be removed if not driving for more than 3 days.
1. With the engine off, plug the Range device into the OBD-II port located under the dash on the driver’s side.
2. When plugged-in, the Range device should illuminate with a blue light.
3. If the blue lights do not turn on, please check the OBD-II fuse (sometimes the same as the cigarette lighter).
4. The Range device will work whenever the vehicle is running.
Notes:
Important:If your vehicle is not a daily driver, please un-install the Range device if the vehicle will sit for more than 3-4 days.
Always remove your device before visiting your automotive dealership. The technicians at the dealership will need access to the OBD-II port in order to run diagnostics on your vehicle.
https://www.rangetechnology.com/blog/post/installation/
flobb is offline   Reply With Quote
