04-04-2024, 02:24 PM | #15 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
I think IMO, there is a difference between actual HP and "usable" HP on road tracks...but I may be wrong.
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
04-04-2024, 03:41 PM | #16 | |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
04-04-2024, 03:45 PM | #17 | |
1/4 mile drag racing is obviously easiest since you’re always running the exact same distance so you can directly compare trap speeds. But if you run the same course consistently then I’m sure you could compare speeds on the straightaways. I’m not a road course guy, but if you have more power than you can reliably put down out of the corners then that’s an obvious problem. Other thing is you need to be able to scrub down that newfound speed before the corner…! I’ll let the road course experts chime in here.
04-04-2024, 04:06 PM | #18 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
04-04-2024, 06:16 PM | #19 |
The Poe Poe
Drives: 17 911 Turbo S, 23' 2SS1LE, 06 S2K Join Date: Dec 2021
Race Weight
1/4 Strip Trap speeds Good HP Calculator Get your answer... My old truck dyno'd 1053 WHP on the DynoJet at Garmon's. Ran it at the track and got the Weight & Trap speeds.... Calculated 1044 WHP Very Very Close to the Dyno confirmed numbers...
2017 Porsche 911 Turbo S - GT Silver
2023 2SS 1LE - 6MT - Sharkskin 2006 Supercharged Honda S2K-Silverstone Metallic 2016 RAM Mega Cab 4x4 Diesel - Silver |
04-04-2024, 06:31 PM | #20 | |
However Torque is more fun on the street. Nice being able to torque around without needing to rev the piss out of the motor.
2016 NFG 1SS A8
04-04-2024, 07:52 PM | #21 | |
Very true. Coyote and A10 is quite the match…always in the powerband and traction is less of an issue on that platform.
