#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Jeezus
#16 |
![]() Drives: 2018 White Convertible Camaro ZL1 Join Date: Jul 2013
I had a huge issue with this when I first bought the car. Washed it, and parked it in the garage for over a week as I was away.
Tried pulling it out... and the brakes were so locked that even slight reverse couldn't break them off the rotors. I had to put some power into it and drag the front wheels about halfway out of the garage for them to break. Crazy. Now, every time I wash the car, I go for a little drive just to dry them off.
White 2018 Camaro A10 Convertible ZL1
#17 |
![]() ![]() Drives: 15 RH Z/28, 23LT1VOM Join Date: Dec 2012
Sometimes contaminated brake fluid(water) will expand and you will experience that optic.
#18 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
If you're really worried about this happening to your car, check out:
Bilt Hamber Atom-Mac. A product specifically designed for this, and used on a lot of auto lots. Spray it on after your wash / dry. ![]()
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
