07-03-2020, 01:18 PM | #15 |
Hot Camaro
I have this same problem with my Sliverado - have had mice build nests on top of the cabin air filter multiple times and it stinks beyond belief if you drive the car with the HVAC on. Only remedy is to pull the cabin air filter, clean everything out, and replace the filter.
As far as traps go, here is what you want to do: - You want to use the ORIGINAL Victor mouse traps ONLY. These are the ones with a wooden base and a springloaded bar. - Bait with peanut butter and pack it into the 'barrel' where the bait goes and don't leave any on the outside - you need to force them to poke their nose in there and move the barrel. - Here's the key: you have to adjust the sensitivity of the traps so that they have a "hair trigger" The two adjustments you need to make are as follows: - The bait holder slips onto a 'staple' in the base to hold it in place. The vertical piece of metal on this component needs to be straightened so that it is closer to perfectly vertical. Don't go all the way to perfectly vertical, just close to it. - On that same vertical piece of metal is a small piece that is bent into the shape of a "V" and extends out horizontally. When you fold over the spring arm, there's a holding arm that comes down and goes under this "V" to lock the trap. Take a pair of pliers and flatten that "V" out just a little so that the holding arm barely stays underneath it when set. And they are super cheap! Do NOT get the ones that have the yellow bait piece that is supposed to "small" like cheese - they don't work. And glue traps are just plain cruel. These original traps are instantaneous death to the mouse. They feel absolutely nothing and their last thought is just how delicious this peanut butter is goi.... These two adjustments done correctly will make that trap work 100% of the time without fail. Here's a pic of one properly adjusted and baited in my garage... |
07-03-2020, 04:17 PM | #16 | |
Drives: 2020 2SS 1LE Join Date: Apr 2016
07-03-2020, 04:18 PM | #17 | |
Hot Camaro
07-03-2020, 04:44 PM | #18 |
07-03-2020, 08:24 PM | #19 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
I’ve been using dryer sheets over the winters and <knock on wood> haven’t had any critter issues.
07-05-2020, 01:11 AM | #20 |
07-05-2020, 06:23 AM | #21 |
Yes I just form a perimeter of them on the floor around the car, sort of like a moat!
07-05-2020, 07:47 AM | #22 |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
I used 2 products from Amazon on my wifes car which sits outside.
Loraffe Under Hood Rodent Ultrasonic Rat Repellent Mice Deterrent with Ultrasound and LED Flashlights, for 12V 24V Vehicle Auto Garage Pest Control, Keep Animal from Chewing Car Wir You'll also see a spray repellant on the same page which also works pretty well. |
07-05-2020, 09:12 AM | #23 |
Drives: 2018 Summit White 1LE Join Date: Oct 2019
I had an RV and didnt want a rodent problem. Many people in the RV community
use Freash Cab, they work very good at keeping them away. I think they smell great. like fresh cut pine and cedar. Just toss a couple under the car, or even inside if you like the smell. https://www.tractorsupply.com/tsc/pr...CAAEgIdOvD_BwE |
07-05-2020, 10:58 AM | #24 |
Hot Camaro
Once you get that Victor mousetrap working, just leave the bodies lying around the car... Future mice will get the idea. lol
07-05-2020, 02:52 PM | #25 |
Drives: 2020 2ss vert Join Date: Oct 2019
I use these traps:
https://www.tractorsupply.com/tsc/pr...2?cm_vc=-10005 Just put a small dab of peanut butter in the small cup and set the trap. No fooling with anything. The trap gets them just behind the head and kills them instantly. No fuss, no mess. It is impossible for the critters to steal the bait. Works every time! |
07-05-2020, 06:31 PM | #26 |
Well we got one mouse this weekend with the peanut butter. Going to try some of the other ideas you all have provided. The new 1LE will b here soon and I CANNOT have them getting in there, too! Thank u all for ur suggestions!
07-05-2020, 07:58 PM | #27 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
07-05-2020, 09:39 PM | #28 |
Not sure if traps are the better way for this situation. Might be better off with using something that repels them rather than draws them in (something tasty). Luring them into a trap is all well and good, but that only takes care of one. Like the old saying if you can see one, there are a bunch more you can’t see.
Not saying traps don’t work, but it gets to be like whack a mole. If you aren’t there very regularly clearing the trap, you are luring more in that won’t get trapped. Went thru this a few years back in my basement. Saw one, so I put out a trap. Got him pretty quick, but noticed a whole bunch more mouse turds. So I put out more traps. Just brought more mice around. Sure I was trapping them at 3-4 per day, but how many more we’re not getting trapped. Finally solved it by finding and plugging where they were getting in. Good luck to you, I hope they stay away from your car. This is the biggest fear I have storing in a public facility. Worst part is, if they damage your car, the rental place insurance doesn’t cover it. |
