Old 09-13-2016, 10:40 AM   #15
mjmenke
mjmenke's Avatar
Drives: 2017 Camaro SS
I just had a discussion with a guy who has been building engines and tuning cars for over 15 years.
He agrees that my numbers are a little high.
His opinion is the correction factor is wrong. Such as they don't have a weather station or if they do it isn't calibrated correctly. The dyno he uses has a real time weather station that can change the correction factor for every pull.
He did however state that running a car in a lower gear will net lower hp than a higher gear. That is assuming you can keep everything cool long enough to complete the pull.
So dynoing in 5th will have lower numbers than 6th. (I'm going to assume I get flamed for saying this)
2017 2SS Black NPP A8 - 422 HP 427 TQ
mjmenke is offline   Reply With Quote
Old 09-13-2016, 10:47 AM   #16
SpeedIsLife
Drives: Current Camaro-less
Otherway around, dynoing in a lower gear results in higher HP figures.
You want to get the transmission ratio as close to 1:1 as possible.
Old 06-07-2017, 09:29 PM   #17
attymf
attymf's Avatar
Drives: 2017 SS
My SS got a baseline dyno yesterday on a mustang dyno of 358 hp and 387 tq. It's an A8. Adding a Procharger so we will see what it adds. As for the low reading, who cares. I Ran a 12.258 bone stock at 115. That's the numbers that matter!
SS, A8, Procharger, M&T's and stuff...
attymf is offline   Reply With Quote
