03-20-2016, 04:01 PM | #15 |
Drives: 2010 IOM 2LT/RS Join Date: Feb 2011
I went with Magnaflow. Sounds great!
03-20-2016, 04:39 PM | #16 |
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH Join Date: Jan 2014
Forget about exhaust for now. The #1 best piece of advice here on C5 is, work from the engine back. You can do this in stages to spread out the cost and ensure you don't make a costly mistake.
I put on ARH LTs with high flow cats into the OE mid-pipe with stock NPP and am very pleased with the sound. I wanted to be careful as I have a convertible and definitely didn't want it too loud. With CAI, ported throttle body and tune, I'm putting down 420 at the wheels (about 480-490 at the crank). To get to 500 at the wheels NA, it's going to take a cam. Anyway, I am super pleased with the power, throttle response and sound of my setup. I believe that it is super reliable since it's all bolt-on and tuning.
Consensus is, by definition, a lack of leadership.
03-20-2016, 05:09 PM | #17 | |
Drives: '10 Camaro SS LS3 Join Date: Feb 2016
WHAT
03-20-2016, 06:58 PM | #18 |
Drives: 2011 2SS Camaro L99 Cyber Grey Join Date: Dec 2015
Exhaust
I have Solo performance and I love it. Not too loud but beep and low.
Check out this link for video clips of exhaust. http://www.camaro5.com/forums/showthread.php?t=21289 |
03-21-2016, 07:10 PM | #19 |
Drives: 15 ss Join Date: Sep 2015
lt's are long tube headers made by arh (id assume), npp is gm performance exhaust ,,,,high flow cats are high flow catalytic converters
03-21-2016, 07:42 PM | #20 |
bump
03-21-2016, 10:48 PM | #21 |
Full American Racing exhaust. you will get the long system long tube headers. you get more power with the longer headers. then the short systems. If you're going to do a full exhaust might as well get a optimized one.
03-24-2016, 01:41 PM | #22 | ||
Drives: 2015 ZL1 Join Date: Jan 2015
The competition is another popular choice, and comes in 3 options: A) 2.5" diameter with center resonator and no rear mufflers B) same as A with center-exit tips, instead of the factory position. An aftermarket diffuser panel will be required. C) 3" diameter with rear mufflers and no center resonator. 3" diameter is only necessary if you are planning on pushing high HP numbers (600+). Last is our race systems which is basically straight pipes. We do not recommend this one for street use and is geared towards track-only cars. It uses the the same center-exit as style as the other Comp exhaust. If you have additional questions about any of our products, feel free to shoot us a PM! |
03-24-2016, 02:28 PM | #23 |
Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
