#15 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
#16 | |
#17 |
![]() Drives: 1987 Buick Grand National Join Date: Mar 2016
#18 | |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Cunningham Motorsports mentioned that drop in kit can be done with the motor still in the car? I didn't know that was possible. Wow.
#19 | |
Drives: 2016 2SS Camaro Join Date: Sep 2016
I forgot to mention I am using Alky Control dual nozzle setup. LT4 injectors and high side....stock in tank pump. |
#20 |
That would flood the car out. The single 10 nozzle was more than enough. I would much rather have a small nozzle turned up then large ones barely working. I don't like leaning the car out to run meth. Not my style.
#21 |
That's fine. Just seems to be a lot of fuel and octane being left on the table. And that is something we needs gobs of with FI. I've always ran my meth wide open and pulled fuel for it. A wise GN tuner once told me to do that, and I've never had an issue.
#22 |
![]() Drives: Nothing cool atm Join Date: Aug 2017
Yeah technically all you need is a flex ball hone to de-glaze the cylinders which anyone could do if they watch a few videos. My question is how are you supposed to remove the oil squirters without pulling the crank? I'd love to know. I also wonder if you could just get away with re using the oem rings after gapping them correctly.
#23 |
The more meth you have the more oxygenated fuel you run, the more power. Beyond just detonation. Then with like a turbo car and a good ecu, you can have fail safe throw rich setup/pull timing if it fails.
#24 |
I understand the theory and agree that meth will make more power. I am honestly struggling with the fail safes in the stock ECM. You can use IAT temps but at a certain point that will fail in my area due to ambient differences. There is no way that I can see using AFR since this ECM doesn't recognize AFR. So someone educated me on what else can be done. I may simply be to busy to think through it. Even with a fail safe that pulls timing you will still be extremely lean under WOT if the meth fails. I understand it will only be till you figure it out but I have seen a lot of people push through a lot of warning signs in the heat of things. So, till I have a better grasp on that portion of things I won't be relying on a secondary fuel source that can fail with a customers motor. Especially a stock motor.
#25 | |
#26 |
I'm running 50/50 mix of M1 Meth and Water. We were on the dyno for a bunch of pulls in the last few weeks. We even ran the car without meth and made way more torque to 4000 rpm, turn the Meth back on and lost 60 rwt at 4000 rpm. I tried a bunch of different pulls with different adjustment. Mine comes on with when it sees boost, the problem is with PD its under boost when you hit the throttle so it start spraying. Mine made 699 with setting at 4 lbs of boost and less meth up top. I wish mine could be set at rpm instead off boost level.
#27 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
I can not imagine tty bolts being reused...If I am not mistaken, they are done after one use because they are stretched.
2016 NFG 1SS A8
#28 | |
![]() ![]() Coolant and oil slushies for everyone when they start doing that. Surely ARP can make studs for the lt1 custom order no problem right? These motors probably don't need l19, so I imagine they wouldn't cost that much either... Can you use lt4 hardware here? Or HG? Last edited by boostednut; 03-20-2018 at 10:29 AM. |
