TireRack
Old 08-04-2016, 12:53 PM   #15
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Originally Posted by CGT View Post
Just put ID1000'S in my LSA blower. They are taller and a pain to install, but....what happened on yours to make you change them?
The fuel rail popped off the top of two injectors. So I kept having to reseat them.
Said **** it and sold them before my car would catch fire and I bought some FIC1000's and they are a perfect factory fit.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 08-04-2016, 12:54 PM   #16
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Originally Posted by jeff657756 View Post
Are you still on a 6 rib setup? Any belt slip with the 2.5?
Yes still 6 rip.
No slip yet but haven't raced it much. Events coming up in the fall. We'll see how it does then.
Had a ton of dyno pulls, was making 680's on back to back to back pulls.
No belt slip then.
Old 08-04-2016, 12:57 PM   #17
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Originally Posted by ttshovel View Post
awesome man!!! you're catching up with me ... and I've got a 9.55/2.5 pulley combo
Yeah! Super solid results. I might eventually do a lower pulley too.
Ryne's dyno reads very low as is, but it's also reading about 5% lower than it normally does, so really that would put me around 721rw lol
But a dyno is just a tool to measure power. We'll see how it actually performs at the strip and Mexico.
Old 08-04-2016, 03:24 PM   #18
CGT
Drives: 2011 SSm6
Said **** it and sold them before my caught would catch fire and I bought some FIC1000's and they are a perfect factory fit.
That sucks! Were you running the fuel rail spacers that came with the ID1000'S?
CGT is offline   Reply With Quote
Old 08-04-2016, 04:57 PM   #19
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Yeah had spacers. After a few heat cycles I guess the injectors got loose and under all the pressure they wiggled out a little.
Not a big deal, car is running at 100% now.
