#15 |
Love my Satin Steel LT-1!
Drives: 6-Speed LT-1... Join Date: Aug 2016
The clutch disc has friction material similar to a brake pad. The friction material is used to slip and eventually grab the flywheel. Riding the clutch or slippage will burn off more of that material than normal driving. I've replaced a clutch on a 6-speed Mini Cooper S that was metal on metal. Also, clutches get hot when slipping, and that heat can damage the flywheel. I've seen hairline cracks on flywheels from too much heat.
2022 SATIN STEEL LT1
6-Speed Man|Carbon Flash Wheels Technology Pkg|NPP|Satin Blk Pkg ZL1 Rock Guards|Red Knee Pad Set PBC LT1 engine built by Debi Lewis |
#16 |
![]() Drives: '23 2SS RSblue 6MT, sold '19 ND2 Join Date: Dec 2021
That's not the enjoyment of driving a manual transmission. Most of the fun is learning how to shift and operate the car smoothly. I used to tell people you know when you've mastered driving a manual car if you can drive the car smoothly while driving slowly without spilling a cup of coffee. It takes proper timing and throttle/clutch control to drive a manual car smoothly when the throttle isnt wide open. I've driven stick for 20 years; this isn't the easiest manual to drive but it's also not the most difficult. Its very rewarding when getting it right. Also, as others have said, you're missing out on a very fun gear. The seat in your pants feel is from 1st gear! There is nothing like revving out this beast 1st-2nd.
If you need help, turn on rev-match. This will help with upshifts as well. Then when you get more used to the car turn it off and see the difference and try to make changes. The drive modes change the throttle input as well, so try to stick to one drive mode at first, like sport or tour. The learning curve for me was starting from a dig because he gears are longer. I always drove japanese cars with very aggressive first gears. All this means is you have to rev it a bit more.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 |
#17 |
![]() ![]() ![]() Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
If you aren’t getting thrown back in your seat in first gear at low rpm it is because you have the throttle in track mode. In track mode I noticed down low it’s slightly dead versus sport and tour and I have to give it more rpm to get going smoothly. Try it out in sport mode.
#18 | |
![]() Drives: 2023 Camaro 1SS M6 Join Date: Mar 2023
Also, once the car and trans warms up the shifter starts to feel a lot better. |
#19 |
![]() Drives: 2016 Summit White Camaro LT2 RS Join Date: Jun 2016
I had a 2004 GTO that reached 100K miles on one clutch...I probably took off in 2nd 3/4 of the time that I had the car. I had a 2012 GLI that I had for over 40K miles that I used 2nd even more with and no problems. First in the GLI was so incredibly short that unless you were wanting to really get up and go it wasn't worth it...
2016 Camaro 2LT | 3.6L V6 | A/T | Summit White | JWM Smoked Side Markers | Flowmaster American Thunder Axle-back Exhaust | K&N Filter | AIRAID Modular Intake Tube | Overkill Tune
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I have been driving a manual since 1979 including now and 99 percent of the time I start off in 1st gear from a complete stop. It lugs the engine in my experience to start off in 2nd gear and wears on the clutch but to the Op you do what is comfortable to you.
#21 |
![]() Drives: 2022 ZL1 M6 Join Date: Mar 2022
I always start in 1st from a dead stop. Yes, the 1-2 shift is a bit notchy but imo there's no real reason to take off from 2nd under normal conditions. Just practice and you'll get there.
2022 Black ZL1 M6
RF intake, Soler TB & TC, ADM v2 reservoir, AWE Touring non-resonated catback exhaust. 535 whp, 537 tq. SAE Smoothing: 5. DynoJet. No tune. 91 octane. |
#22 |
![]() Drives: 23 Camaro ZL1 Join Date: Mar 2023
do all 23 zl1 m6 have skip shift? I haven’t experienced it yet.
#23 |
Try and shift from 1-2 at a low rpm and it'll surely kick in
2022 Black ZL1 M6
#24 | |
To the OP's question: I do not do 2nd gear starts. I don't like feathering the clutch that much to get the car rolling. Now once underway in first gear and if I want to just loiter along, I will shift 1-3-5-6. Or sometimes I shift 1-2-4-6. In fact there is so much torque available you can easily go 1-3-6 or many other combinations. Now when I want to rip on it - it's 1-2-3-4 and then lift to keep from getting the car impounded for excessive speed! ![]()
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) Last edited by SSDan; 06-22-2023 at 06:45 PM. |
#25 |
![]() ![]() ![]() ![]() Drives: 23 ZL1 6speed Join Date: Aug 2020
It sounds as though you need more experience with driving a manual. In anything I’ve ever driven, I’ve never consistently started in second gear. There’s a reason a car has 1st gear. You’re claim of basically having no torque/power starting in first makes no sense. It’s a 6.2 V8 with plenty of torque and the car doesn’t weigh that much.
#26 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
#27 |
Not if you momentarily blip the shift lever to the right in between 1 and 2. That's one way to defeat it.
#28 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 6th gen Join Date: Aug 2013
Op Try 1-3-5 shifting for around town. 1st gear might be slow because of traction control
