11-10-2016, 12:13 PM | #15 |
Drives: 2017 Camaro; 2017 Acadia Denali Join Date: Jun 2016
Check engine light should not illuminate unless you try to start the car with the MAF sensor unplugged.
11-10-2016, 12:55 PM | #16 |
Pat
Drives: 2017 Camaro 1LT I4 Turbo A8 Join Date: Nov 2016
11-12-2016, 09:01 AM | #17 |
Pat
Getting Crank Case Fitting tube off
How do i get the crank case fitting hose off the stock intake tube? Seeing to be harder than expected
11-14-2016, 01:35 AM | #18 | |
Drives: 2016 Camaro RS 4cyl Turbo Join Date: Oct 2016
Notice how the gap goes from the top in the first picture, to the bottom. That gives you the room to push the clip up and to the side |
11-14-2016, 07:56 AM | #19 | |
Pat
11-14-2016, 07:57 AM | #20 |
Pat
11-14-2016, 08:00 AM | #21 |
Pat
11-14-2016, 08:09 AM | #22 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Just checked mine. It's just like yours. 2017's seem to have a different fitting. It does look like it should push down and twist off. Great talk here though. Once you figure this out it will be of great help to many. Hang in there the answer will come.
Kindness and compassion #OthersFirst |
11-14-2016, 08:14 AM | #23 | |
Pat
Will keep posted. If anyone else has any insight as to how i get this godforsaken ventilation tube off, please help! |
11-14-2016, 08:15 AM | #24 |
Blessed ❤️
Just came to me. The hole on the fitting. Looks like you stick like a small screwdriver there and gently push. That may release a tab so you can pull up?
11-14-2016, 08:33 AM | #25 |
Pat
I tried. Felt like it was going to break. This past Saturday, i took the stock intake out in about 3 minutes and had the Injen one all set to go. tried for about a half hour to finagle that clip off. I searched the depths of the internet and found nothing. I just don't want to break the piece. I tried a tandem "clip-push-in with my father and it was not budging. I think it may be: push down, twist and pull off because if you look inside the clip, there is a vertical groove which im sure is not there for aesthetics.
11-14-2016, 08:50 AM | #26 |
Blessed ❤️
Yep, I agree. I just tried to push the tab and it is not budging. Now we just need to figure out the trick of this push and twist fitting.
11-14-2016, 08:59 AM | #27 | |
Pat
Autozone was a total waste of my time. The guy was like "umm yeah i dont know try googling it, sorry man"....................... Anyways, don't break anything but keep trying and let me know if you figure anything out, i wanna get this CAI in ASASP |
11-14-2016, 08:59 AM | #28 |
Blessed ❤️
I sent Jason@Jacfab a message to look at this. He will know what to do.
