06-14-2017, 03:52 PM | #15 |
Drives: 2017 ZL1 Join Date: Aug 2009
TravisLambert isn't the only one who has experienced heat soak at the drags. People on here thought it was funny I was using portable fans to help cool the intake and engine between rounds at the strip. As long as there is no flow through the intercoolers, there will be heat soak. I'm pretty sure that making a few passes in a row at the drag strip will yield less of a loss in et than making one pass, and then sitting for a few minutes to let it cool off.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY https://youtu.be/Lcu41obbTf8 '13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight. http://youtu.be/yggIA3C_kkA 2014... back to stock http://youtu.be/spQLaTWbThs 2013... stock & RotoFab |
06-14-2017, 07:52 PM | #16 | |
Bring It
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
06-14-2017, 08:03 PM | #17 | |
Drives: '17 ZL1 Join Date: Jul 2016
I think turning the car off, setting up a big fan blowing onto the center and driver's side heat exchangers, and forcing the intercooler pump on would be a lot better though. |
06-14-2017, 08:09 PM | #18 | |
The car really needs a cool down mode like the dodge demon where it will run the fans and coolant pump with the engine off. |
06-14-2017, 09:29 PM | #19 | |
Bring It
Well I drive it to the track anyway, so I'm not sure the temps would exceed whatever they were at during normal driving if you're just idling.
06-14-2017, 11:41 PM | #20 | ||
Drives: X-15 Velocipede Join Date: Mar 2008
Camaro Team: Nailed it!vvvvvvvvvvvvvvvvvvvvvvvvvvv
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
06-15-2017, 05:56 AM | #21 |
It will absolutely heat up more idling than driving because the airflow from the fans is not as good as the airflow from the normal driving. That's why it's so common for parade vehicles to overheat.
06-15-2017, 07:46 AM | #22 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
I've often felt it takes several thousand miles for an engine to fully break in and loosen up. While it might be trivial, I wonder how engine temps are effected as the frictional losses decrease over time from a new low mileage engine?
06-15-2017, 07:56 AM | #23 |
Bring It
Ahhh good point.
06-22-2017, 09:30 PM | #24 |
I'm confident that our ZL1's do MUCH better than the late-model Corvettes in dissipating heat, but believe there's merit in the suggestion that there could be added benefit in larger coolers that are thermostat-controlled and allowed to run regardless of whether the engine is running.
I made 15 passes with my ZL1 at the Arkansas Mile earlier this month and saw the impact of heat build-up firsthand. With afternoon temps around 91 degrees and a wait of 15 minutes to an hour between runs, I saw a definite drop-off in performance. Putting a 20-pound bag of ice on top of the SC between runs got me back about 2mph at the mile mark. Talked with several drivers who had installed intercooler chiller systems that circulate iced water during their runs and they claimed to get 4-6mph at the mile. |
06-23-2017, 07:12 AM | #25 |
Drives: Getaway Special Join Date: Jan 2013
BECKY! 4 already! Is that where you let out your aggression? You are so amazing... living life to the fullest!
Sip:
06-23-2017, 07:34 AM | #26 | |
Drives: Duramax Join Date: May 2017
You should be using a handheld IR Thermometer to measure AND LOG some of the follow temps; 1) Engine Block 2) Radiator 3) Transmission/Clutch Assy 4) Coolant Lines 5) External Coolers 6) Rear Axles 7) Brake Assy/Rotors 8) TIRES(graduated) 9) Drive Belts 10) Forced Induction, (graduated) 11) Exhaust Manifolds(independent) 12) Driver 13) Wheels (If I've forgot something please feel free to edit as I haven't had my coffee yet) Keeping a log of both the location, time and ambient temps can tell you alot about how each component is performing or not performing. An EGT Temp can be handy when tuning or diagnosing an engine. Here's a good handheld IR FLIR TG54 Spot Infrared Thermometer DON'T FORGET TO LOG YOUR DATA |
