11-29-2017, 09:34 PM | #15 |
I have this "Hard Drive Handle" only on the six speed. I have the ball as well but prefer this. My only complaint is it gets hot in the summer and my hand sticks to it from the cold in the winter. I made a leather slip cover that laces on for the cold.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
12-01-2017, 04:13 PM | #16 |
Drives: 2010 Camaro SS Join Date: Dec 2006
For me...it was primarily the look. Truth is...the stock throw isn’t too bad. But first and foremost, it absolutely needs to function well. I had your shifter and had to take it out because it made 1-2 shifts grind like crazy. Put my stock shifter back in...everything went back to normal and clean shifts.
I also didn’t like the noise it made. Rattled like crazy. Maybe you should make 2 versions...a smooth shifting quiet version for the look. And a short throw agreasive version for those who want to deal with the downsides of that. Thank you for reaching out for some voice of customer! I really wish I could have kept my Hurst shifter in. And I hope you guys can come up with what I’m looking for. |
12-01-2017, 05:35 PM | #17 |
Drives: 2015 BLK/BLK 2SS/RS MN6 Join Date: Oct 2016
I bought one used from a forum member and for me, it is 99% form and 1% function (see pic in my profile album). I love the looks but I find function is notchy and quite sloppy. It already has the newer bushings but again used so who knows.....I get zero noise from it and it works okay so I'm keeping for now. I would buy in a minute a complete shift kit as some of your competitors are selling already and actually considering one myself. If only...
12-02-2017, 07:00 AM | #18 |
Drives: 2014 Z/28 #398 Join Date: Dec 2014
I love my Hurst shifter
12-04-2017, 10:19 AM | #19 |
Drives: 2010 SS Join Date: Jun 2015
I liked the old school look but HATED the locking nut on the ball rubbing the inside of my fingers. Also i think the HURST snifter needs to come with the HD bushing kit out of the box not as an upgrade.
01-15-2018, 07:13 PM | #20 |
Drives: Camaro SS Join Date: Mar 2010
Actually reply to support tickets (1+yr & still counting), remake the "white" t-handle, offer different size/version/bend "sticks", nylon bushings fix (offer or include brass @ NC), fix the excessive rattle under acceleration, re-engineer for smoother shifts (too hard/sloppy), do I need to keep going.....?
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
01-21-2018, 08:17 PM | #21 |
Drives: 2014 1ss camaro Join Date: Jul 2017
I found an automatic hurst shifter at a swap meet and welded bolts on both ends with a t handle and I can shift easile
02-03-2018, 05:24 PM | #22 |
For the Hurst people...can you describe the difference between the factory Hurst shifter in a 2011 AS and the aftermarket billet plus shifter?
02-03-2018, 09:05 PM | #23 |
Drives: 2015 Camaro 1SS Black Join Date: Jan 2018
Hurst shifter
I second this statement.. why should we have to purchase the upgraded bushing kit ?? Basically you are telling us your product will not hold up and lacks quality as is... you're basically charging us for obsolescence ... also why don't you offer a pistol grip for the 5th gen but do so on the challenger , mustang, 6th gen ?????????
02-06-2018, 01:08 PM | #24 | ||||
Drives: 2013 Camaro SS and 2016 Camaro SS Join Date: Jun 2014
We are glad to hear it! We appreciate your support. Quote:
In regards to sticks, we do offer a wide selection of Hurst Sticks that can be found here. As for the shift quality, depending on the use of your shifter, it is possible that the included bushings could be starting to wear causing a sloppy feeling. Those bushings can either be replaced with the standard bushings, or our Pit Pack Extreme Duty Bushings. However, as those bushings are constructed with a 303S stainless steel jacket and lined with polymer liner, there will be added NVH over the standard bushings. This is the reason we do not include them with the shifter as majority of our customer prefer the standard bushings. Quote:
Rest assured, we stand behind our shifters with a Lifetime Limited Warranty, meaning that you can enjoy your Billet/Plus shifter without any worries about getting the support you need should any issues arise. As for the offering a Pistol Grip version of the shifter, we have only recently begun offering both the Classic Ball and Pistol Grip options for newer vehicles. Depending how high you are willing to have your shifter, you could replace the included stick with one of our Pistol Grip sticks. |
02-07-2018, 08:43 AM | #25 |
GPI Sales Consultant
Your competitors manage to make their shifters both precise and quiet, and you don't have to buy extra parts. I removed my Hurst Billet Two Plus as it had worn bushings and was very sloppy, made tons of noise, and would grind aggressive 1-2 up shifts. Went to the OEM shifter and all of those issues instantly resolved.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
02-07-2018, 02:37 PM | #26 |
I ran one in two different camaros. I hated how the bushings wore out so fast and even the "upgraded" ones wore out fast. The shifter always felt sloppy even knew. Ya it was a step up from stock.
I switch to MGW and the difference was massive. I think the fact you all use the factory mount for the shifter is the big issue. Also the stick was way to long. It did not feel like a short throw at all.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
02-07-2018, 05:28 PM | #27 | |
Drives: 2010 Camaro 2SS Join Date: Aug 2016
02-09-2018, 03:41 PM | #28 |
Although it's not always what we like to hear, we do appreciate your feedback. Our 10-15 shifter was designed as a street/strip style unit with the primary goal of reducing shift throw as much as possible. Although other shifter characteristics were somewhat secondary in the 3916030 model, we used the feedback that we received from 5th gen shifter owners when designing our Billet/Plus shifter for the 2016+ Camaro. The additional "dogbone" section in our 6th gen unit increases isolation dramatically and makes for a much firmer and quieter unit overall. That being said, we have considered redesigning our 2010-2015 Billet/Plus shifter and incorporating this into the design, but this will of course increase the cost of the shifter. The competitor's shifter that was mentioned is a very nice unit, but it does come in at a considerably higher price point than our current offering which has always been quite popular and very affordable. We are open to putting together a sample shifter using the 6th gen isolated stick design and upgraded bushings to send out to a forum member for feedback. But, when all is said and done an updated 10-15 Hurst Billet/Plus shifter will cost somewhere in the neighborhood of $100 more than the existing Hurst 3916030 shifter and in order to move forward with production on an updated shifter, we would need 50 Camaro owners to step up and commit to a purchase. How many of you would be interested in an updated version of the Hurst Billet/Plus shifter?
