06-18-2019, 01:52 AM | #15 | |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
06-18-2019, 09:15 AM | #16 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
What pyrometer unit will you be using?
06-20-2019, 06:56 PM | #17 |
I've tried 36 hot and still too far away from the Goodyear symbol. I'm trying 34-36 hot this weekend which is only going to be 95 at COTA. For sure you want a accurate pressure gauge to use. The Longacre one I have is +/-0.2 psi
06-20-2019, 07:16 PM | #18 |
Mmmm IDK think that is too low. Maybe the track you're on too, and tires not being pushed to roll as much. Likely they will get rather greasy pretty quick. I've been told before not to adjust for tire "wear" based on air pressure alone!! That means you will need a pyrometer probe, not just a air pressure gauge. This will tell you if your alignment specs and pressures are appropriate for your driving style for that particular track. The next track will most likely be needing different specs, but most of us can not afford to deal with such particulars to that level.
06-23-2019, 10:21 PM | #19 |
My mistake, meant pressure.
What meter do you recommend if I want to start measuring tire temps?
06-24-2019, 08:03 AM | #20 |
Drives: 2018 ZL1 1LE 2022 GMC AT4 HD Join Date: Dec 2014
Front 39psi hot
Rear 37psi hot Sounds like a lot of pressure but worked very well for me |
06-24-2019, 08:19 AM | #21 |
Drives: Rally Green 2020 ZL1 1LE A10 Join Date: Jul 2018
Based on scrub lines alone this tire (Left Front) is over inflated, the pressure was right at 38 and I saw 39 occasionally. So id imagine if I was at 37 ( I believe that's the recommended hot pressure for RC driving) It would be right at the top of the wing or pretty close.
It was really hot that day by the way and started with 30 PSI. |
06-24-2019, 08:42 AM | #22 |
Drives: 2013 C6Z06 Join Date: Nov 2016
I see feathering all the way into the lettering on my front SC3s. I know the pic doesn't show the sidewall, but look at the outside edges. You guys can push so much harder...
06-24-2019, 10:37 PM | #23 |
Sorry for delay been up at Mont Tremblant and spotty service. I honestly do not know what pyrometer to recommend. I have a cheap infrared one, and I had a guy that does my track alignment check mine with a probe pyrometer at my last event to check the latest alignment spec's and wear. Sorry!! I'll ask what unit he is using tomorrow...
06-24-2019, 11:56 PM | #24 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
06-25-2019, 12:00 AM | #25 | |
NB i did have a "proper" pyrometer. Never left the box lol! I find managing by pressure and wear marks to be completely reliable. Imo anyway. |
06-26-2019, 02:16 PM | #26 |
No wings left here! Still running these tires btw.
06-26-2019, 03:57 PM | #27 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Do you risk a blowout if you run tires much past the cords showing?
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
06-26-2019, 04:17 PM | #28 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
I run:
Front 26 PSI Cold Rear 27 PSI Cold Track alignment per track supplement. Target is 35 PSI hot. GY SC 3's will wear closer to the sidewall mark as they wear down. The tires start square and will round the outside edge after 5+ track days.
Tags |
psi, sc3, scrub-lines, tire |
