#2717 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 GT350 Join Date: Jan 2011
"Even a cursory glance at the speed trace (above) should leave you wondering, "How the heck does the GT350R wind up only 70 feet behind the ZL1 at the checkered flag?" The Camaro is dramatically faster on the front straight, grips better around the long, lower-speed Turn 2 and slingshots around the very quick Turn 8 faster than the Shelby. But the Ford catches up in nips and bits—a little here, a little there."
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot |
#2718 | ||
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
The R had a LOT of advantages. Let's say the suspension between the two cars were similar. Ok so the ZL1 had the HP/TQ advantage. Outside of that every other advantage went to the R. The ZL1 is fully optioned and heavier. Part of the weight advantage that goes to the R is rotational mass (CF wheels) which makes up a lot. The ZL1 also has that heavy blower on the front making it nose heavy. And the RPMs are nowhere as high as the R. So do you really think that having one advantage did the trick? It is obvious that the ZL1 is on a much better chassis than the R is. And the entire car was built perfectly, unlike the R. Even down to the tires. GM did not settle for an off the shelf tire like Ford did. They contracted GY to make a tire specifically for this car. So how else could a car that is not built for the track beat the snot out of a purpose track built car? The R should have done better than it did despite the HP/TQ deficit. And the fact that the SLE matched it also proves that something was lacking in the Ford camp. Face it. GM did what Ford did but better and all in a package that includes everything and doesn't have to be pieced together. |
#2719 | |
2019 GT350 RR
#2720 |
Well the Camaro was built right the first time so they didn't even need the A10. It was more just a fancy new gadget to throw in as incentive to attract potential buyers. GM doesn't typically do major changes. Unlike Ford who seems to always have to completely redesign the entire damn Mustang after 2 years and finally when they have it right they move to the next Gen and it gets slower. But, the A10 did close the gap and made it a driver's race and that was all that they needed to do. They more than likely are working on the 8th Gen at this point while Ford is trying to figure out if they should allow you to add coolers or a "Tech Package" AND a "Drag Package" or if they'll just let you have one or the other for the 7th Gen.
#2721 |
#2722 |
![]() ![]() ![]() Drives: 1999 Camaro SS M6 - SBE LS1 Join Date: Jun 2018
An argument that shows the ultimate R handling Mustang, finishing behind a base ZL1 on a road course is EXACTLY how I figure the Camaro chassis and leaps and bounds better than the S550 for handling.
Again, not even in the same ZIP code as the ZLE. So I reiterate - the GT500 is in a seriously tough spot. Attempt to dethrone Mopar on acceleration, or attempt to handle like a ZL1/ZLE...
1999 Camaro SS 6M - SBE LS1
1994 Camaro Z28 6M - Golen 383 HT 1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 |
#2723 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
...and it won!
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
#2724 |
![]() ![]() ![]() Drives: 2013 Camaro convertible 2SS/RS Join Date: Sep 2014
#2725 | |||||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 21 Bronco Join Date: Jun 2012
Be honest Camaro faithful, before any real performance numbers were out there on the 6th gen did any of you expect the SS 1LE to almost match the outgoing 75K Z/28? I agree the only reason they kept the 350 around is so they had a top end model and the GT wasn't top of the range Quote:
BUT I do see what you are saying that for the buyer it would take away value, but that is a free market. As long as their are people willing to shell out extra $$$ stealerships will charge it. Quote:
Now this is just different views, I accept that Ford short sightedly only aimed the 350 at the Z/28, so I don't fault it for not beating the ZL1 at anything. That is just me though, you are entitled to your opinion. And just so everyone is on the same page, Ford did not settle for an off the shelf tire, they had Michelin make the tires specific for the 350 "The Michelin PilotSportCup 2 tires were specifically tailored by Michelin for the GT350R The high-performance tires — 305/30ZR19 front, 315/30ZR19 rear — have a special compound and tread pattern just for use on the Ford Shelby GT350R Mustang. Pericak says that Ford and Michelin worked on countless variables and changes, mostly concerning things like sidewall stiffness and the exact rubber compound used for the tread. Incidentally, those rear tires are slightly wider than those on a Camaro Z/28; that car packs 305/30ZR19 Pirellis all round." https://www.automobilemag.com/news/6...t350r-mustang/ Quote:
#2726 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
It will take more tire every time to compete with an equal model Camaro, and that is due to the alpha and nothing more.
J-Rod Built and Matt@FSP Tuned |
#2727 | |
The can release whatever they want in the form of a GT500. It doesnt matter how it performs or doesn't, it WILL sell and Ford knows it. The insane delay on release does make me think they want it to perform like it should though, very excited to see what they offer. I hope it isn't another dud though. The voodoo pretty much stains the GT350 reputation, which sucks as it is also its best feature.
#2728 | |
Is this practice only accepted if it is a GM product?
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot Last edited by newmoon; 11-27-2018 at 01:09 PM. |
#2729 |
Agreed, it makes sense for the 1LE competitors. I hope someone will put the PP2 against the SS 1LE for a direct head-to-head, I'm not interested in bench racing stats from different days (that goes both ways).
#2730 | |||
To answer your question, Mark Reuss said it in 2014. One year before the first cars hit the street
