Old 03-25-2017, 04:11 PM   #2661
Nated421
Nated421's Avatar
Drives: 2017 50th Anniversary SS Camaro
Put on these zl1 addons rock gaurds on my Fifty today. Look pretty good.
Nated421 is offline   Reply With Quote
Old 03-25-2017, 05:43 PM   #2662
smeech
Drives: 2017 Camaro 2SS, 2006 GTO
Had the windows tinted. 35% sides, 20% rear. Suntek CXP film.
2017 Camaro 2SS Black w/ Ceramic White Interior, M6
2006 GTO, CGM, w/ Aussie VZ Front, SAP side and rear, mildly modded, M6 (FS Soon)
2016 Sonata Hybrid. Really??
smeech is offline   Reply With Quote
Old 03-25-2017, 09:27 PM   #2663
Hyper16
A Heartbeat Away.........
Hyper16's Avatar
Originally Posted by chozn4service View Post
ZL1 Addons jack pads. A must have and a pain in the tail to install being 6wks Post Op bilateral knee replacement surgery and really shouldn't be on the ground. Not a lot of room to work with when screwing the set screws inward position. Two down and two to go. Time for a hydrocodone!!!!!!
....image.....
I have a set of those ready to install as soon as the weather gets a little better. Do you think there is any chance they could fall off while driving. I mean, how securely do those set screws hold. Thanks.
Old 03-25-2017, 11:39 PM   #2664
JeromeS13
Drives: 2017 1SS/1LE
They're pretty secure. I added some loctite for extra insurance.
Old 03-25-2017, 11:55 PM   #2665
JetBlast77
TxAg80
JetBlast77's Avatar
Drives: '17 1SS 1LE, '00 Integra Ty R
This was the first thing I did. They do fit on as tight as you crank down on the Allen wrench. I rubbed the threads with anti seize compound mixed with a little oil. Run the threads in and out a few times to lube them up. Also dab a bit on the end of the set screw where it clamps down on pinch weld. This will minimize your time under the car with the jack pad three inches from your face. I, also have some trouble getting under the car so if you are going to be jacking up your car a lot put a small piece of painters tape under rocker panel where just visible and center it up with your jack pad so you can easily line it up without getting on your knees. I also paint a line on the jack and line up the paint mark with rocker panel to get the jack under the car just the right distance. No more getting on your knees, at least not for jacking.
Ordered Summit White 1SS 1LE 12-27-17
1100 on 1-7-17, 3000 on 1-24-17 TPW 2-20-17,
3400 on 2-7-17,3800 on 2-20-17, 6000 on 3-6-17
10 weeks
.Typical drive home from work
JetBlast77 is offline   Reply With Quote
Old 03-25-2017, 11:58 PM   #2666
JetBlast77
TxAg80
JetBlast77's Avatar
Also the instructions say to retighten after jacking a few times. Each have two set screws and should be fine. I'm not worried.
10 weeks
Old 03-26-2017, 12:29 AM   #2667
HyperBlue16
HyperBlue16's Avatar
Drives: 2016 Camaro RS
Just did mine also, black and added blue loctite also. After the dealers mess up and adding the GFX kit.
HyperBlue16 is offline   Reply With Quote
Old 03-26-2017, 01:43 AM   #2668
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
I thought the same thing and thought how bad it would be for this block of metal to become detached, hit the ground, then the underside, then the ground and start its bouncing. Not good, this is not good in my Goose to Maverick voice!
No I do believe these set screws will hold the jack pads in place. I ensured that I they were flush to the underside of the body while in position of the pinch weld. I laid all I had into tightening them up and went over them twice. I will set I had the set screws set in such a way that when I pushed them into place they just barely pushed on to the pinch weld bit I heard them slam up against the body and it gave me less to tighten in the laying down position with the set screws on the other side of my direct view but I set up a mirror to help with that.
Never grow up, it's a trap!
chozn4service is offline   Reply With Quote
Old 03-26-2017, 04:08 PM   #2669
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
Wait so those things get perm installed to car?
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
Adrian97c is offline   Reply With Quote
Old 03-26-2017, 04:13 PM   #2670
VJChevelle67
The Beast
Drives: 2016 2SS Camaro Convertible
Smile what i did today for my Top off SS
Hi guys and gals made sure the battery was up to snuff for the comming year been sitting all winter ,, covered
VJChevelle67 is offline   Reply With Quote
Old 03-26-2017, 04:17 PM   #2671
chozn4service
Yea, that's why they have set screws to secure them. Otherwise you could buy the magnetic one that has the red flag to remind you to remove it before driving. These that I have stay on which which makes it convenient since you have to have these.
Old 03-26-2017, 04:34 PM   #2672
keon718nyc
Kinda like the fact you can have these screwed in place and not have to worry about taking it on and off. Another addition to my list
Old 03-26-2017, 04:56 PM   #2673
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
So you guys gonna check under the car everyday and make sure they are still there?
Old 03-26-2017, 05:58 PM   #2674
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
FWIW - and don't ask me how I know - the magnets on these are pretty strong by themselves let alone with the set screws. After a 50 mile round trip I know for a fact a magnetic jack puck will not fall off.
476 rwhp/440 rwtq (sold)
