Old Today, 07:23 AM   #253
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
Originally Posted by bishopts View Post
Also Fuel coming in over the intake valve from port injection can pull heat off the valve, which can bring cylinder temps down, which can bring overall combustion temps down to reduce NOx.
Dual fuel has more flexibility. If they were to pair them together but run the port injection off the high pressure fuel pump, it would create a better atomization than traditional port injection. But the tight space it will be limited to could end up with the fuel cutting the metal in the intake port.
You could also run a periodic maintain routine to clean the valves of carbon build-up.
Direction injection has the ability to inject raw fuel into the cat in the exhaust stroke to warm it faster or hotter.
I feel one of the best improvements auto makers could do is make wide band sensors smaller, and have one on each exhaust port. I know no two engines are the same so I'm pretty sure no two cylinders are the same. So if you could more accurately control fueling for individual cylinders, the overall efficiency and performance would be better.
The wide band sensor thing would be cool but I can’t see any manufacturer doing that due to cost. I’m just happy GM finally started using them on CT5 blackwing and in”think” the LT2 if my memory is correct. Makes tuning way easier, safer and better
2012 Shelby GT500 with VMP Gen 3R.
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
