Old 05-10-2023, 05:31 PM   #253
cjperformance
cjperformance's Avatar
I wouldn’t write the port “issue” off just yet. So you added port and had no slip…but the more power you make the more you’re relying on the port. So if the torque mapping is off, it will get worse as you make more power. If/when I add port my local tuner was insistent I put it on the dyno in hopes of making reported torque match up to actual. Just my 2 cents of course. I don’t believe in coincidences.
Understood. Torque was added via the EQ Torque Coeff table per Mike's advice. But what i didnt do was account for the pulley down.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 05-10-2023, 05:32 PM   #254
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Yeah I’m sure Mike is on the right track as usual…but was it enough is my question.
I need you and Rad to get this all figured out for me before I buy it.
Old 05-10-2023, 05:39 PM   #255
toohighpsi
Drives: 2015 C7 Z06 M7
Zoom in on the narrow band O2s at the point of the knock (change the scale in the plot), they can be an indicator to let you know if the knock is real or not.
What are your knock sensor settings? I like to leave them close to stock when running full E85 as you have lots of octane there - especially on an LT1.
Do a compression check, I've always been able to tell if you have a broken one with compression check.
I will say that I did blow the front seal out of the old Magnuson Camaro SS pretty early on, fortunately it didn't hurt anything - wasn't totally sure until we pulled it apart to upgrade to a 416, but when it came apart - sure enough all the pistons were still good. SO - blowing out a seal is likely accompanied with a piston problem on an LT1, but fortunately its not a guarantee of a broken piston.
Your data looks OK to me, I probably wouldn't expect a problem at the numbers you're showing there.
Mike
www.toohighpsi.com
2015 Corvette Z06 M7
2021 Porsche GT4 M6
2023 Corvette Z51
Old 05-10-2023, 05:45 PM   #256
cjperformance
If the mechanicals check out, and i get the seal fixed, then maybe ill get it down to CBI for a dyno tune.
Im secretly hoping its blown so i have an excuse to do upgrades Ok not really, but I'd like to run some 9s someday.
I think the 1 for 1 port swap was VERY straightforward. Its basically all math. If i screwed up anything, its with the pulley down.
Old 05-10-2023, 05:50 PM   #257
cjperformance
Thanks Mike. I can take a look at that tomorrow and post up some more data on that.
Old 05-11-2023, 09:58 AM   #258
cjperformance
6 of 8 plugs out... number 7 lookin sus.
Def some oil on the threads.
2 more plugs to go then compression time.
Old 05-11-2023, 10:21 AM   #259
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Finger's crossed for you buddy.
'20 ZL1 Black "Fury"
Old 05-11-2023, 10:25 AM   #260
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Your tuner won't have anything to worry about. I would have been done a while ago if I stuck with the traditional method, but because I'm difficult - I didn't go that route. I'm close, though, and just trying to get the throttle transitions figured out. That's the last part of the puzzle I think. I still have MAF polishing on the REFLEX, but my WOT numbers are on the rich side, up top, so I figured I'd come back to the tough part, which is this transitional stuff.
Your guys wouldn't have ANY trouble doing this though. For the record: I'm not having ANY trouble with the REFLEX or AND of the PORT hardware. This is all my ineptitude and stubborn'ness, LOL.
Old 05-11-2023, 10:26 AM   #261
cjperformance
1 and 7 at 250 psi. On to the others i guess.
Old 05-11-2023, 10:31 AM   #262
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
At least #7 doesn't look like it's far out yet.
Old 05-11-2023, 12:09 PM   #263
cjperformance
Ok, so all cyls are 250 psi +/- 5 psi except #6 which was at 260.
Only suspect thing is #7, which has some "fluid" on the spark plug and darker grey coloring on the ceramic as shown in the pic in my earlier post. All other spark plugs (except #7) look almost identical to the other 3 shown in that pic.
The fluid on the plug seems thinner than oil, but doesn't smell like fuel. May have a little blow by there... not sure. My first thought was maybe a weak coil, something causing an intermittent misfire, or maybe a bad/dirty injector and that it was fuel not oil. But the sniff test says it isn't fuel.
I only did a compression test today. I'll do a leakdown on the driver side cyls in the next few days, just to see if I can figure out what's going on with #7. I wouldn't even worry too much about it except the other 7 plugs were just so identical in color... so SOMETHING may be up with #7, but compression checks out ok.
Old 05-11-2023, 06:11 PM   #264
laynlo15
Drives: 2022 Lt1 A10
If you have that much compression in all cylinders your probably ok, those are the highest cylinder pressures I've heard of, mine were all in the low 200s except 1 that had none and 8 that had 65 psi, I could have those reversed since its been a few years since I broke the first Lt1. Number 7 may have been a little richer then the others so may be some additional fuel on the plug. I don't think your going to need those Mahle Forges pistons I have. Maybe I can talk Mike into a Live tuning school for tuners, amateurs and professionals that are tuning the ECU and the Reflex.
Old 05-12-2023, 09:31 AM   #265
cjperformance
What do you guys recommend for a damper puller? Will I need something specific, or will any 3-jaw work?
I've seen some references to the OTC 6667 for puller...
What about an install tool? I have an install tool with needle bearings, but it's for an old-school SBC. Not sure I have the right thread adapters... Plus I have to find it first. Been 20 years since I used it probably :( . Any recommendations for an install tool?
Old 05-12-2023, 08:48 PM   #266
toohighpsi
I think I have this one - not necessarily a good one as the pushrod bowed the first time that I used it, but have pulled the damper from our Z06 and Camaro a few time so far.
If I was a shop I'd invest more in a better one - but if you only plan to use it once or twice...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Looks like it's currently out of stock, but there are similar ones like
https://www.amazon.com/MOSTPLUS-Harm...8YRBQ8BZ&psc=1
Don't think I used an installer, just the old bolt with some moly on the install the balancer, then swapped to a new bolt and torqued it (with a big electric impact)
Mike
www.toohighpsi.com
2021 Porsche GT4 M6
2023 Corvette Z51
