#253 |
Petro-sexual
It's almost shocking how fast the gauge falls after running E' for the first time. I knew it was going to increase to a certain degree, but it was still a bit of a surprise to actually see it.
OH WELL!!! At least it's a lot cheaper than our crap 91.
#254 |
![]() ![]() ![]() Drives: 2023 ZL1 - All Bolt On's Join Date: Dec 2022
For my application, 2023 ZL1, probably nothing more than looks and extra sound !
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•BGRF•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#255 |
Quick Update on the catch can and oil polling up in supercharger issue: So, as pointed out to me by Camaro1973, the issue was related to vacuum pulling excess oil/vapor back through the catch can and into the intake under boost. After working with Elite (they have been excellent) and emailing Mike at Katech. It was confirmed that Katech valve covers don't have internal baffles, thus, and as Camaro1973 pointed out. I needed a restrictor in line on the clean side port. So I could order the needed restrictor from Elite and install it. But, this doesn't solve the entire issues as Elite support pointed out in great detail. The stock EVAP box is connected directly to each of the Katech valve cover PCV ports, which don't have baffles. I guess Katech must be running some sort of "vacuum" pump to prevent this on their builds? Regardless, I decided to go with a set of new DSX valve covers that have internal baffles. Kind of whish I would have know more about the mechanics of how all this works before I originally order what I did.
Quick Update on my Flex Fuel Tune: For my remote re-tune and flex fuel adjustments. Ted Jannetty, Sr. worked his magic! We are solid on E60 for my setup! Car runs great and the exhaust pop and crack are mostly gone, unless it's a high RPM decal, then it pops cracks a small amount. I hope to get a local dyno run and see what kind of HP I'm at!
#256 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Great write up... thanks for the update, i also installed a restrictor on my MM set up, and since then, oil is pulled into the system about 80% less than it did without it. Looking forward to seeing your dyno numbers!
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#257 |
![]() Drives: ‘23 ZL1-1LE Join Date: Mar 2023
So 19 pages in, would you still have gone down this rabbit hole? Honestly it’s painful to read. I feel bad for you, yet you keep throwing more money at it.
#258 | |
Take Care!
#259 |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
Hey guys great information! What diameter restrictor did you guys use, something like a .1875 id/ 3/16”? I think it is a good thing to have in line even with stock motor.
#260 | |
This is what MM sent me... It was installed on the CC vacuum line side. Hope this helps... Side note... MM was great at helping me through this trouble shooting and adjustment.
#261 | |
There are some videos showing gains on higher HP cars... I did mine for the looks and sound, if it helps on the HP it was a bonus IMO.
#262 | |
![]() Unlike you, I feel "proud" of the OP more than "sorry". He rolled up his sleeves, and I am sure loved most of the process. Better yet, he takes the time to share his experience... even the mistakes, so the next reader may not have too. Cheers to modding, sharing and learning from one another.
#263 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#264 | |
Petro-sexual
Good Lord... 30* of timing after all the modifiers?! SHEESH!!! You're "only" at around 1.26g (average of those logs) of cylinder airmass I see, but wow. I wonder what JRE is commanding at higher airmass. I'm only commanding about 25-26* where I'm at (total - around 1.55-1.60, before the new upper I just added) for E75. WHEW!!! I haven't seen many tunes, so maybe this isn't that big a deal. What's your cam timing at, if you don't mind sharing? I'm typically running about 5*, but am playing with up to about 7* @ WOT. I start getting knock above that (well - that was on about a 94-octane blend of gas and about 21-22*).
#265 |
![]() Drives: 2019 ZL1 Join Date: Jun 2022
#266 | |
![]() Drives: 2021 Camaro ZL1 Join Date: Mar 2023
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, BMR Cradle Lockouts, Atturo 315 AZ850DR |
