Old 07-19-2018, 12:32 PM   #253
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
probably dipshits that torqued my strut down when they installed my new yyz springs lol had another place replace the strut and torque and locktight the endlinks and swaybar bushings and no issues so far been about 2 or 3 months now
Old 07-19-2018, 01:46 PM   #254
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Bummer about the guys who probably broke it.
Emoto is offline   Reply With Quote
Old 07-19-2018, 01:54 PM   #255
kropscamaro16
yea shit happens lol oh well
Old 07-20-2018, 09:09 PM   #256
joe944
joe944's Avatar
Drives: 18' A10 ZL1 , 18' F150, 04' MSM
My front right has started making an increasingly louder clicking sound as I go slowly over speed bumps. Could be making the sound at other times but I can't hear it. Looks like I need to check mine...
Earlier today my car wasn't recognizing my key and I had no AC or ventilated seats. Ugh.
Looks like the fun is beginning at 5k miles...
joe944 is offline   Reply With Quote
Old 07-25-2018, 05:38 PM   #257
JimmyZ
JimmyZ's Avatar
Drives: 2017 1LE
End Links
Mine started to make noise a few days after i hit an imperfection in the road a couple weeks back. got so bad i parked the car until i was able to get an appointment. Took this TSB in with me and explained to the person behind the desk that it might be this issue. After an all day affair they finally called and said it was loose end links and it is not covered under warranty because i hit a pot hole. I calming replied to the person on the other end of the phone, do you remember the piece of paper i gave you at 745 am this morning. it says exactly what you told and yes, by the way, this is a warranty item. It was already after hours and the service manager was gone, so he has to talk to him tomorrow morning.
Frustrating, that you try to provide some guidance, yet they do their own thing. I even mentioned at 9 am when they were giving me a rental car that maybe they should put it on the alignment lift and look at the end links because all he was doing was putting on the lift and letting the wheels hang.
anyway one more 1le with this issue.
JimmyZ is offline   Reply With Quote
Old 07-27-2018, 03:53 PM   #258
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
Mine are doing the same. Took to dealer and they had to order new nuts and apply locktite
CruzySS is offline   Reply With Quote
Old 07-31-2018, 09:43 AM   #259
Teneck83
Drives: 2018 SS 1LE
Curious how you guys use the Allen key to prevent the end link from moving AND use a torque wrench at the same time
2018 ZL1 1LE
1966 Corvette 427/425 vert
1969 Corvette 350/350
Teneck83 is offline   Reply With Quote
Old 07-31-2018, 11:42 AM   #260
Nvr2tall4SS
Drives: 2017 Camaro 2SS
Mine started clunking at about 8k. Was pulling out of the driveway and clunk it started. Happens sometime more than at other times but no specific event occurred that I found to cause it. Dealer took care of it no problem.
Nvr2tall4SS is offline   Reply With Quote
Old 08-02-2018, 10:16 PM   #261
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Mine is clunking now after 4000 miles and 8 track days. Will be trying the Nord-lock and loctite fix
Old 08-03-2018, 01:01 AM   #262
satanschariot666
Drives: camaro
can I tighten them down when the car is on ramps or can I only do it when the wheel is off the ground?
I am hearing weird pulsing sounds on the passenger side when I take left turns hard. Do you think this is causing this?
satanschariot666 is offline   Reply With Quote
Old 08-04-2018, 10:47 AM   #263
carguy55
carguy55's Avatar
Like this...
Old 08-04-2018, 09:48 PM   #264
CruzySS
CruzySS's Avatar
Had the tsb done and the front end still makes the noise. Sounds like a POS!
Old 08-20-2018, 04:54 PM   #265
IH8WNTR
Drives: 2017 1SS 1LE Silver Ice Metallic
Originally Posted by carguy55 View Post
Like this...
I understand how to tighten it but how do you know what amount of torque you are using? Also iirc, once you use loctite, the amount of torque used should change right?
IH8WNTR is offline   Reply With Quote
Old 08-22-2018, 12:26 PM   #266
IH8WNTR
Anyone? I’ve got an appointment with the dealership but would much rather handle it myself.
