Old 01-26-2025, 01:57 PM   #253
DeuceCam
Drives: LT1
^Those look great! I'm considering a set. I wish they offered an 11" wheel with an offset similar to the SS-1LE spec, but it looks like the 12j +41 will work.
The rear tire looks slightly stretched - what size did you use?
How much negative camber do you have out back?
Your car looks lowered - what suspension do you have?
Any rubbing?
DeuceCam is offline   Reply With Quote
Old 01-27-2025, 02:03 PM   #254
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
There is a 19x11 et44 in the BMW fitments, that will work. I have a set of these that I will be running in a square setup on my 1LE, it was the only way for me to get 19x11 square with these, so I'll be running a fat spacer in the front but rear fitment should be perfect. You could pair them with either the Camaro or BMW spec 19x10s in the front.
IG: @NC_M1SS1LE
Old 01-28-2025, 02:21 PM   #255
DeuceCam
Drives: LT1
Thx for the heads up!
Old 01-28-2025, 10:28 PM   #256
Mike Aruba
Mike Aruba's Avatar
Drives: 2016 2SS
Any rubbing?
The 12” rear works fine for me with zero rubbing. I’m running 285/35’s up front and 305/35’s in the rear. The rear has a very very small bit of stretch. I think I’m running around -1.5 camber in the rear but it’s been a couple years since I get the car aligned. Planning on getting another alignment soon. Yes the car is lowered a bit. I’m on Silvers coilovers.
Mike Aruba is offline   Reply With Quote
Old 01-29-2025, 11:29 AM   #257
DeuceCam
Drives: LT1
Those wheels are so good.
Old 06-24-2025, 06:11 PM   #258
SPLATT
SPLATT's Avatar
Drives: 16 Camaro 2SS
American Racing TTF in 20x11 et43 and 20x9.5 et15 in anthracite grey with Continental Extreme Contacts in 305/30 r20 and 285/30 r20. Don't mind the dirt, I live on a dirt road and haven't washed this week.
SPLATT is offline   Reply With Quote
Old 06-25-2025, 02:48 PM   #259
DeuceCam
Drives: LT1
Wheels:
  • Manufacturer: Variant
    Model: Helium
    Color: Black Semi-Gloss (it's more of a satin color)
    Front: 19x10 +20
    Rear: 19x11 +40
Tires:
  • Manufacturer: Nitto
    Model: NT555 G2
    Front: 285/35/19
    Rear: 305/35/19
