Old 11-04-2018, 02:40 PM   #2535
ULTRAZLS1
ULTRAZLS1's Avatar
Originally Posted by smokinzx14r View Post
What is WR ?
WR is weight reduction. which is a false statement to say it has no WR imo
Drag wheels/tires is one of the single biggest weight reduction mods you can do. Around 100 lbs and it’s rotating weight which is worth even more.
Old 11-04-2018, 02:43 PM   #2536
smokinzx14r
smokinzx14r's Avatar
Drives: 2018 1SS
Thank you ... I looked up the DA on that time ticket
Density Altitude: -1406 feet ..Not a chance we would ever see that kind of air here in FL .. I'm surprised the track was even open in 36 Deg temps ..
smokinzx14r is offline   Reply With Quote
Old 11-04-2018, 02:57 PM   #2537
FastCarFanBoy
Drives: 2013 GB GT
He had to have it rebuilt can’t recall why. Don’t believe anything was done as far as performance or different ratio etc just reliability stuff
What battery is 5lb for 350? I had another slightly smaller battery and had issues with not starting.
https://www.ebay.com/i/232836087253?chn=ps
had 1 in my car for about 9 months now. Starts like a champ.
FastCarFanBoy is offline   Reply With Quote
Old 11-04-2018, 03:16 PM   #2538
FastCarFanBoy
Drives: 2013 GB GT
It's Canada, 36 is shorts weather. Even when we do get negative d/a here the water grains are ludicrous high.
Drag times says -1000 the owner said -900. if you look at the 2pm data on dragtimes the humidity is 29% at 2pm but 40%+ at other times so i dont know exactly but it wasnt -1400
Old 11-04-2018, 03:59 PM   #2539
smokinzx14r
Drives: 2018 1SS
I got the numbers off Drag times so go fight it out with them not me ..
Old 11-04-2018, 04:10 PM   #2540
FastCarFanBoy
Drives: 2013 GB GT
Not sure what Drag Times you're using...
Old 11-04-2018, 04:19 PM   #2541
ULTRAZLS1
ULTRAZLS1's Avatar
Thanks
My battery is actually 25 lbs. might be worth the swap this winter
Old 11-04-2018, 04:43 PM   #2542
FastCarFanBoy
Drives: 2013 GB GT
Thanks
NP....I'm using the ATX 12-24. made a simple hold down out of aluminum flat bar stock from Home Depot.
don't forget these https://www.ebay.com/itm/Antigravity...item468795281e
Old 11-04-2018, 05:20 PM   #2543
ULTRAZLS1
ULTRAZLS1's Avatar
Thanks
The atx 30 re start model for 40 bucks more looks appealing as well. Still only 5 lbs, has the re start feature, more ah and cranking amps
I’m actually seeing it for 359 on some websites...
What are you using for a charger ? Wonder if my battery tender will work.
Old 11-04-2018, 07:19 PM   #2544
FastCarFanBoy
Drives: 2013 GB GT
Thanks
my car is my DD so no charger. You need a special charger for the Li-on batteries but unless you rarely drive your car or have a drain of some sort I dont think its needed. Also i read something about the restart feature not playing nice with a guys Boss 302 on SVTP. That was why I went with a non-restart model and guys are going 3 weeks between starts with no issues.
Old 11-04-2018, 07:20 PM   #2545
Stroked84
Drives: Nothing fun, currently.
Originally Posted by BlaqWhole View Post
2010 - Camaro 426 HP Mustang 315 HP ()
2011 - Camaro 426 HP Mustang 411 HP
2012 - Camaro 426 HP Mustang 411 HP
2013 - Camaro 426 HP Mustang 420 HP
2014 - Camaro 426 HP Mustang 420 HP
2015 - Camaro 426 HP Mustang 435 HP (Finally surpassed the SS after 5 years)
(Unless it was an automatic, amirite?)
Stroked84 is offline   Reply With Quote
Old 11-04-2018, 08:11 PM   #2546
wnta1ss
Drives: 2017 Camaro 1SS
The re-start battery does not play nice with our charging system. I know somebody that had a lot of problems in a 6G Camaro with one of the re-start versions. Car goes dead and you can't open the trunk to hit the button for the re-start feature.
Old 11-04-2018, 09:05 PM   #2547
ULTRAZLS1
ULTRAZLS1's Avatar
Ok thanks for the heads up
Old 11-05-2018, 09:00 AM   #2548
GuywithL86
Drives: Black
Front skinnies main advantage is that it changes to weight distribution more to the rear
Anything to take weight off the front will net huge traction gains
More weight on driven tires = more traction = more acceleration = more weight on driven tires. It’s a compound effect. It’s why a dodge demon runs anywhere from 9’s to 11’s. If you can’t get 100% of the vehicle weight (wheelie) on the rear tires you’re going nowhere
GuywithL86 is offline   Reply With Quote
