Old 06-13-2018, 07:52 PM   #239
gtrules50
Big Pappa
gtrules50's Avatar
Drives: 2017 Camaro ZL1 A10
I just bought a brand new left over 2017 ZL1 two weeks ago & with 500 miles on it I hear the clunking in the front end. Glad I searched this forum so I can tell the dealer tomorrow to check the sway bar end links. Damn thing still has the drive out tag. LOL!!!
gtrules50 is offline   Reply With Quote
Old 06-16-2018, 07:51 PM   #240
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
Mine just started doing this. Going slow hitting cracks in the road it makes a thudding noise with a rattle? Is this what everyone else is experiencing? Thanks
CruzySS is offline   Reply With Quote
Old 06-16-2018, 08:01 PM   #241
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Sad-ass engineering and quality control. Shame on you GM.
Tested for thousands of miles, confirmed by thousands of owners;
You can't (or refuse to) solve this simple mechanical issue. Year after year.
l
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 06-17-2018, 09:57 AM   #242
Badmojo
aka BeastZL1
Badmojo's Avatar
No issues so far. 3500 miles with ~280 miles on track. Fingers crossed.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 06-20-2018, 10:52 AM   #243
MATTY-1LE
MATTY-1LE's Avatar
Drives: 2018 Camaro SS 1LE
Is this an issue for 2018 1LE's too? Crap i already have a cabin rattle i have to address
Current:
2020 V6 A10 - looooving the regular unleaded, over 20mpg, and excellent daily driver manners!!!!!
Past:
2018 1SS 1LE - stock
2008 C6 - heads/cam/boltons
2005 GTO - cam/boltons
MATTY-1LE is offline   Reply With Quote
Old 06-20-2018, 11:06 AM   #244
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
A bit of clarification please. The clunk that I had was very slight. When you have the loose end link nut issue, is the clunk immediately noticeable, without question?
I did bring the car in and they said all the nuts were loose. I'm not sure I buy that. I still get that very light clunk at times. I'm thinking it's something else. My previous car, a GTI, did something like that and it was the aftermarket sway bar bushings, which require periodic lubing.
I did bring the TSB with me, including the update for the nuts. I verified with the parts department that they were in stock, but they did not change them. They said tightening is required first. Pretty dumb.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 07-03-2018, 08:45 AM   #245
nascarazy
nascarazy's Avatar
Drives: '18 ZL1 & '17 2500HD Midnight Ed
First loose end link was right side at 3900 miles. 300 miles later, now the left side has same problem. Wish they would have serviced both sides at the same time, but "your original problem was only the passenger side." This is getting old already.
2018 Camaro ZL1 - Garnet Red Tintcoat[/B]
- Order Placed@ dealership 8/12/2017
- 1100 8/21/2017
- 3100 8/23/2017 (TPW 9/11)
- 3400 8/25/2017
- 4300 9/11/2017 (VIN available)
- 4200 9/15/2017
- 4200 9/20/2017 (on train near North Platte, NE)
- 4200 9/22/2017
- 4200 9/23/2017 (car in town)
- 5000 9/25/2017
- 6000 9/26/2017 (Finally in our garage!)
nascarazy is offline   Reply With Quote
Old 07-12-2018, 10:14 AM   #246
Tara Martin
Loves Camaros
Tara Martin's Avatar
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert
I've had loose sway bar end links most of my car's life. It started rattling early on before the TSB, so I tightened them myself. They loosened again, so I retightened and used Locktite. The TSB came out with new nuts and Locktite, so since I was getting the front spring TSB done, I told them to do the sway bar end link TSB as well. Now, about 8 months later, loose sway bar end link nuts again! I took it to a local shop and they put it up on a lift. Previously, every time I tightened the nuts, it was the left side only that was loose. This most recent time, after the GM TSB, both sides were loose and the right side was the worst! At my own time and expense, I had them tightened again.
This is getting old. A $65K car rattling like a 30 year old pickup truck? Why can't they get this right?
Old and new, sharing space!
Tara Martin is offline   Reply With Quote
Old 07-14-2018, 10:13 AM   #247
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
On a 2SS, if I put the car up on ramps, will I be able to get to the nuts that loosen up and check and/or tighten them?
Emoto is offline   Reply With Quote
Old 07-18-2018, 12:19 PM   #248
Tara Martin
Loves Camaros
When I did mine on the ZL-1, it was on a jack stand and had the tire/wheel off. It was easy to get to, then.
Tara
Old 07-18-2018, 12:22 PM   #249
Emoto
Sure, why not?
Emoto's Avatar
Tara
I'm sure it was!
I would like to avoid removing any wheels if possible, hence my question. Also, didn't someone mention earlier that there had to be weight on the wheels for the looseness to show? Or am I confusing that with something else?
Old 07-19-2018, 08:25 AM   #250
Emoto
Sure, why not?
Emoto's Avatar
The other question I have is has anyone done a fix and NOT had the clanking come back?
Loctite, special washers, aftermarket end links, whatever. Am wondering if there is a permanent fix.
Old 07-19-2018, 10:59 AM   #251
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i finally got my clunk issue fixed lol was my broken front strut
Old 07-19-2018, 12:13 PM   #252
Emoto
Sure, why not?
Emoto's Avatar
Any idea how it broke?
