#239 | |
![]() Drives: 17 SW 1LE Join Date: Jun 2017
#240 |
I have 6 track days on the OEM pads, 3 at a big fast track and 3 at a smaller slower track and have about 6.6mm pad left on the fronts. New is about 9.8mm
Use the AcDelco number for the best price at Amazon, Wal-Mart, CarID, Rock Auto to name a few. |
#241 | |
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
I saw that the Raybestos pads seem to do pretty well with longevity, but what about other track pads you guys are using? A friend of mine has some Carbotech XP20s with a nearly identical caliper/rotor setup on his GTO and has run 10+ days on them, most of those days being driven in 2 different run groups, and still has over 50% of the pad material remaining. Wondering if it's cheaper to keep going through the OE pads at a faster rate but less cost, or spend a bit more for real track pads that last longer...
2017 SS 1LE.
#242 |
![]() ![]() Drives: ISO ss 1le Join Date: May 2018
20% off stock pads
Thought I would share.
tip: Make sure to place two separate orders for fronts and rears. If you purchase together, it will only take 20% off the cheapest item (20 bucks off the rear). If you purchase separately, it'll take $43 off the front's and $20 off the rears. Make sure to click the 20% box. Fronts: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Rears: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Last edited by Move_Over; 07-09-2018 at 07:04 PM. |
#243 | |
![]() Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
Links aren't working? For me anyway... |
#244 |
#245 |
#246 |
I used the PowerStop Track Day pads Friday at COTA for five 25 minutes sessions. Ambient temp was 96, a cooler day than what we had the week before.. I liked them once I got them hot and got used to them I could brake as late as I was brave enough to try. I could stop at a later braking points without any hint of fade. In one of the slower sections I got on the brakes hard and thought I felt the ABS for a split second, but that never happened again. I was running in the intermediate group and not pushing it to the max everywhere but did set a new personal lap time by 1 sec during the 5th session. Not sure if it was the pads or the fact that I had dialed in the tire pressures right or track temps had dropped or that I was trying to catch a GT350R, which I did. Based on my experience and the cost I would use them again without question. They also did not turn the Brembos into Brownbos. I have also used them once on a smaller track without issues.
#247 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
#248 | |
![]() Drives: 2017 SS 1LE Hyper Blue Join Date: Jun 2017
I’ve just tested Ferodo DS 1.11 race pads and it turns out they’re actually too aggressive for the OEM discs. So this is really saving my ... for the upcoming trip to Belgium. They even ship to Germany and get here by Wednesday already! |
#249 | |
![]() Drives: 93 RX-7, 17 SS 1LE, 04 RX-8 Join Date: May 2017
Could you explain what you mean by the DS 1.11 being to aggressive for the disks? From my experience rotors heat crack out before they wear down on heavy cars like these. Were the DS 1.11's wearing the rotor dramatically? |
#250 | |
(They’re using mostly DS 2500 for that reason) On the way back it smoothened out again with some highway braking, just like they predicted. I only have 1 year of track experience, so I can’t tell for sure, but it looked to me like the discs were getting quite some beating. (New discs, new pads. Bedding in on the way and easy first session with good transfer layer all over) With stock pads or DS2500 I was getting heat cracks but no grooves. Any opinions? |
#251 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
#252 | |
I would have liked to keep the pads on, but my tendency is now rather to opt for stockers for Spa and Hockenheim next week. Would have to switch tomorrow.. |
