Old 06-13-2016, 07:18 PM   #239
diirk
diirk's Avatar
Drives: 2016 Camaro SS
Originally Posted by AbsolutHank View Post
Got your email. Thanks brotha!
Any time. Lmk if you need anything else.
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad
91 Miata 1.8 Feal Wilwood Track Car
1morproject
diirk is offline   Reply With Quote
Old 07-03-2016, 09:03 AM   #240
laynlo15
Drives: 2022 Lt1 A10
Dirk has yours dropped a little more in the rear. It looked like the rear was higher then mine. Did you keep the rear loose until you dropped it down?
Old 07-03-2016, 09:49 AM   #241
diirk
diirk's Avatar
It's a little lower. I'm very happy with the stance. Perfect.
I didn't do the indexing process, if that's what you're asking.
1morproject
Old 07-03-2016, 11:13 AM   #242
laynlo15
Bmr calls it indexing, I've lowered so many cars and trucks that it just something I've always done. Just have to let it settle and do all the tightening on the alignment rack. Measure yours sometime from the bottom of the wheel just to see where your at. Your car really looks good. I like our stance better then the bmr set up.
Old 07-03-2016, 11:21 AM   #243
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
You need to and should not omit it to slightly adjust ride height. Remember suspension bushings are solid molded rubber between an inner and outer sleeve. Any suspension arm movement twists the outer sleeve with respect to the inner. Correctly indexed movement would be ~x degrees of twist in both the up and down directions. Incorrectly indexed could be as much as 0 twist at full down travel and 2x twist at full up travel resulting in additional stress and premature bushing failure. Suspension bushings shouldn't be working as helper springs.
LibertyHill is offline   Reply With Quote
Old 07-03-2016, 11:35 AM   #244
laynlo15
I would take to your alignment guy and let him break all the bolts loose, retighten but don't torque and drive down the road, then back on the alignment rack. Loosen again and re-align it. Anytime the suspension is in a bind it can cause a harsh ride and as stated above premature ejaculation of the bushings.
Old 07-08-2016, 08:01 AM   #245
diirk
diirk's Avatar
Just to update, I did get this done. Ran by the alignment shop and even though they thought I was nuts, we went through and indexed the bushings.
I honestly don't know if this is really necessary, but did it anyhow. I'm still not really buying the general premise behind it. Bushings are meant to move and rotate around an axis. If the car is lowered, the bushing will rotate to the new center point. Otherwise, every time you hit a large bump, you'd twist/tear the bushing and they wouldn't last one road trip. The only time I could see this really being an issue is if someone over-torqued the bolts causing the bushings to bind, and that would be an entirely different issue.
1morproject
Old 10-14-2016, 03:55 PM   #246
Ricardo@Phastek
Ricardo@Phastek's Avatar
Drives: the boss nuts....
Send a message via AIM to Ricardo@Phastek Send a message via Yahoo to Ricardo@Phastek
Progress!!
Alright guys!!
It has been a long time coming but here is an update on what we have going on.
The pictures below will show a factory spring and our new design. The issue we had with the previous batch has been fixed. We are going to put a few miles on our shop car with the new springs just to make sure we do not have any issues, so far we are happy with the fitment.
The ride height shows to be about 1/4" higher then the previous springs but we are hoping they will settle a bit and close that gap to where it was before.
Once we give the green light to go ahead with production we are looking at about 3-4 weeks before we have them ready to go. I know I have been getting messages on C6, Facebook, Instagram, and many phone calls about these. Stay with us guys we are working on it!!
Sorry in advance for the cell phone pics......
Stock Springs:
Phastek Springs:
Ricardo@Phastek is offline   Reply With Quote
Old 10-14-2016, 10:08 PM   #247
Jooseep
Jooseep's Avatar
Drives: 2017 Chevy Camaro 1LT V6 M6 Mosaic
Will these be for the V6 as well?
Jooseep is offline   Reply With Quote
Old 10-17-2016, 09:05 AM   #248
Ricardo@Phastek
We do plan on testing on a V6 car once we have another set to test. I have a local customer that is going to allow us to use his car, so I do hope to find out soon enough.
Old 10-17-2016, 12:04 PM   #249
bdar66
Drives: 2016 camaro lt2 rs
i dont see how this would be any diffrent the lt and the ss have the same suspension
bdar66 is offline   Reply With Quote
Old 10-18-2016, 03:16 PM   #250
Ricardo@Phastek
Yes, but confirmation is key. We want to be sure that there will be no issues with fitment. Once I do confirm I will update for sure!!
The go ahead is going to be given to our manufacturer. So production will start soon and be completed around December. Hoping to have some sets before that time.
Old 10-19-2016, 07:47 AM   #251
diirk
diirk's Avatar
Looking forward to trying these out.
Has the test vehicle settled any more? Current ground to fender height?
1morproject
Old 10-19-2016, 10:39 AM   #252
Ricardo@Phastek
I do have you in mind when they come back.
The car has settled and we are at the same measurements as the previous springs. The car drives just fine, no issues with any bumps. We have put about 100 miles on the car with these springs and we are going to a show on Saturday that is a bit of a drive for us, so we should be more road time this weekend.
I will get some measurements for you shortly.
camaro springs, lower, lowering springs, phastek springs, springs
