#225 |
Measurements of a bad pulley shaft
All boxed ready to go. P3gauge should be inbound. Die Camaro on breakfast bar waiting for strips and silver wheels. Beer open....I'm just WAY TOO busy...LOL
Black material all in pressure side of case, heavy in spots. Coupler material or engine oil threw PCV?? I don't have the catch can, maybe I need one. Upside, nothing in intake ports. Highest amount on screws. Shaft for pulley (wobbling pulley) is way to funny. Mount surface is .015 out top to bottom.(thats the wobble front to back) Now, make that bigger with the pulley. Run-out was .011, thats the up and down. BUT, The end play was .001, and NO detectable excessive gear lash. |
#226 |
Haha! I'm really racking them up with gains like 4hp. I was more looking for a smoother throttle and changing some of the cold and warm start specs
#227 | |
That is it, that's his personal car too. I think it was first LT video, I believe he has a CTS-V, so it would be an LT4
#228 | |
#229 |
I'm not sure if its oil or coupler. I smelled, tasted and played with it. If it was oil, you would think that it would be on vacuum side, were line attach from OEM catch can (nothing) Coupler, if there is one, would be right at screws, were the most material is found (clumps on the screws) Then dusted in the case. Whipple is suppose to let me know what they find. I think Mike (whipple) got upset when asked if monkeys machine his parts. (I am NOT politically correct sometimes)
#230 |
WELL, maybe I been selling Whipple short. BUT, as a lot of you know, this has been the "SCREW BRETT BUILD"...LOL (Rob can do his own...lol) My work is spot on, it has been the other cooks in the kitchen that screwed it up. Anyhow, Whipple jumped on the return shipping (I Emailed, stated ready, Fed-Ex pulled up) P/U was 7-11, will be there 7-14, per tracking....WOW. One day to fix, and I asked Mike to inform me what they found. I know the shaft is junk (wobble).
But My concern is the material found threw-out the pressure side. Is it coupler, engine oil or gear box oil? I don't want to hear from third party, what was wrong. "I" NEED to correct this, owned 1 year, 2300 miles, enjoyment, to be updated later...LMAO. SO, If shipping is right I should have it 7-21. P3 gauge here tomorrow, I'll install and wire in. Then CK boost, might have an 3.125 pulley to get rid of. Joe has a couple, he bought to BIG...LOL. |
#231 |
Since my SC is still out, and my mind is still working.
I got the Mishimoto catch can. PROBLEM: Clamps (included) can be used on large hoses. Crimp clamp are the way to do. BUT, fit small screw clamps will work. Drain for Maintenance is crazy. So I am installing, threw the OEM plug (metric) a drain. To drain between oil changes. THEN: the boost. I went with the analog sensor, P3. But have to drill and tap for the barbed fitting. Haven't figured where I'll do that yet. Maybe rear plug (drill tap) All this is 5/32 hose, 10-32 unf) |
#232 |
Well, that was fun. Now I can drain catch can between oil changes, then remove yearly to clean.
SC will be here tomorrow. Whipple did find a problem with the input shaft, hence the wobble. Also stated that could have been some of the noise. No concrete answer on the black material inside the case. I would like to know if any other Whipple owners, After removing the lid, had black gritty crap in theirs. On my yearly I do plan on removing lid for inspection |
#233 | |
![]() Drives: 2014 Camaro ZL1 Join Date: Oct 2014
When the car left it had an airbag light as well as an abs light however my scanner would not connect and I even drove the car to another shop to try and get their tool to communicate with those modules but when they wouldn't I recommend that he should take it to the dealer. He stated that he knew people at the dealer and they would take care of it. I said perfect no problem let me know what they say. He later called back and said they couldn't do anything for them. So I took the time and called my mobile guy that writes modules for GM and setup an appointment so that we could try and get the car figured out. (even though it was not my fault). He then called me back and said that would not be necessary and that he found the problem with the burnt harness (not our doing) I stated that would cause that let me know when your ready to make more power. At this time he mentioned to me that a spark plug wire was missing and I let him know that I am sorry that happened and that I would take care of it if it still needed put back on. He then stated that he took care of it and it was not a big deal and I assured him that it was not like that on the dyno or during my test drive, as it did not have a misfire that whole time. As for the re tune yes we charged him $650 for the tune and we charged 1 hour to install new wires with boot protectors. He then changed the pulley and needed a retune I told him before he left if he changes anything that requires it to go back on the dyno I charge by the hour and it should only take an hour. He then called to make an appointment after doing the pulley and my service manager stated that it should only be an hour or 2 and we charge 155 an hour. He then decided to yell at my manager for 23 minutes about how i told him $100 and my service manager stated that I probably said 1 hour and after 20 min he finally agreed that it may have been stated one hour not a dollar amount. During this conversation he continued to tell us how he is a 30 year mechanic and an ex marine. My service manager thanked him for his service as a marine but didn't understand why either of those had any relevance to the situation. A week later he rights a bad review on BBB about how we screwed him over and never called back. I was on vacation that week and returned Monday to find the review and when I tried calling him there was no answer and no return call. I then do a little research and find this slander and build thread. Seeing that he was beating on the car before a tune of any sort was installed I am amazed that it did not blow up before I even got to see it. If there is no engine damage done at this point I am still surprised and that may be a reason for so much oil in the blower and lack of power do to blow by. During the time we had the car he rides his 3 wheeled motorcycle into our shop area where it clearly states employees only with the radio blaring. This was truly surprising to me as a 30 yr mechanic you should know not to do this. Keep in mind it is our only garage door to our 15000 sqft facility, and our customer entrance is clearly marked and has to be passed by to enter the door that he drove in. Every conversation myself or any of my people had with him was very hostile and very confusing as he would not listen. I encourage you to do your research to see what we do and what we have done before drawing any conclusions from this guy. |
#234 |
I finally had time to really read this fairy tale above. Earlier, I just skimmed through it, wasn't really concerned with the lies posted by "Big 3 Little Piglet Racing"<<< My new name for them....LOL.
Lies from the start "have not posted much" (was his FIRST post)<<Quote from Chuck (Owner< truth,"ONE of the owners)......THIS POST IS FILLED WITH LIES. (and bad grammar) I had a bad feeling about them from the beginning. I should have taken notice. Never addressed any issues, (CEL'S, BS dyno report) He did address the raw gas smell in his comment to the BBB. More concerned that I ride a Trike and listen to my radio loud (hearing issue) I beat my car (should have blow up) and all that blow by (Whipple's report is, PTFE deposits) I did copy and print their comment (above) to add to the dyno, and other worthless paperwork. These will be all framed and displayed at every car show and event I attend. When I was younger, I used to just walk away, and not bother by thieves like them. But now older, I feel people should be aware, so they don't become victims. I could go on and on, making reference to Big 3 Little Piglet Racings statement. But I have more important things to do. They can worry about that, while they're fine tuning their next scam instead of someone car Last edited by brettman; 07-22-2017 at 03:40 AM. |
#235 |
OK, big day today, RE-inspect SC (I hope it's OK) then re-install. Can't start it yet, catch can 45 degree fitting not here. I do have to figure out how I'm going to run my boost hose. I have a real problem drilling holes in a new car firewall...LOL.
I don't see any problem having it all ready (except fitting) to go today. Not really a big job, just time consuming. |
#236 |
Fabricated (well, found fittings, drilled for hose barb...lol) Does that count as fabbed? Upside, the port used "IS" below the LH IC (higher then MAP) I believe it will read pretty accurate boost. But then again I'm not an engineer. I don't even know how to drive a train.
On to CK-ing Whipples work, with dial indicators, before I drop the housing on. |
#237 |
WHIPPLE KNOCKED IT OUT OF THE PARK.
Measurements posted. They came threw, hats off. Shipping (2 day back). Yes, ON- OFF-now back ON. Why am I alway the test monkey...LOL. The thing is guys, if it WOBBLES, jumps up and down. It will run....for awhile. Maybe forever...Is it right?? for $7000.00. Don't get me wrong, they took care of Rob. They took care of me. They are stand-up PPL, unlike what I have deal with. CHECK your SC, wobble (run out, lash, end play.) crap falls between the cracks. If you say nothing and it comes apart....Your BAD I'll have better update on mine when I start, and abuse that thing like the 3 pigs think.......WE WE WE all the away to the bank ...I know, I'm bad, I tell the truth....LOL Last edited by brettman; 07-22-2017 at 07:51 PM. |
#238 |
![]() ![]() ![]() ![]() Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
So glad you are getting closer to tearing up the streets. My car is looking like it's going to hit a pretty good trap speed when i get to the track. I'm going to datalog first and probably dialer in "if it's needed" before I hit the track. But so far it is looking like a solid 10 second car which I like especially being a M6 and using me as the driver mod. And sadly I'm sitting at 261 "just had my physical and going for my pre-operative studies on Monday for my back surgery", so I just need to do a half driver delete mod after surgery and it will look even better. LOL
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
