Old 03-03-2021, 08:04 AM   #225
Justinwilliams258
Justinwilliams258's Avatar
Drives: 2019 camaro ss
Hopefully some one sees this and can help me out. I'm looking to get new wheels I'm just not sure about offset I understand it but not sure what offset works with our cars I am currently looking at the niche rainier 20x9 35offset 20x10.5 35 offset I was told the fitment isn't for sure and no returns is it doesn't fit. I am trying to get it to where my wheels set flush with the fenders maybe just very little poke I am also looking at the variant argon 20x9 25offset 20x10.5or11 35 offset since I think the 25offset in the front gets the look I'm wanting can anyone help me out thanks!
Justinwilliams258 is offline   Reply With Quote
Old 03-03-2021, 09:17 AM   #226
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
I think you’ll need a spacer on the 20x9+25 (if you truly want them flush). Just bolting them up it’ll stick out 0.25” more then the stock SS wheels. If you want more you’ll need to space it. +35 is way to much (or run a large spacer).
Rears will be nice at +35 on a 10.5” wheel. +35 on a 11” might start to poke a little.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 03-03-2021, 10:54 AM   #227
Justinwilliams258
Awesome thanks! Do you think the front being 20x10 with the 25 offset would be better?����
Old 03-03-2021, 11:23 AM   #228
Chrome383Z
Chrome383Z's Avatar
Yes. +20-25 is the ideal offset for 20x10. +20 is 1LE offset, but pokes a little. That’s what I have and like it but some don’t. 23 is probably perfectly flush and 25 would be slightly set in but your splitting hairs at that point. I’d prob go with the 25 and you could always put a 1-3mm spacer to tweak it to exactly where you want it. If you go too low on offset (like 20) you are stuck with it.
Old 03-03-2021, 12:45 PM   #229
Justinwilliams258
For sure! Do you happen to have instagram? Would like to see some pics! I think I will be going with the Variant Argon Gloss Piano Black*20×10 5×120 +25mm offset
20×11 5×120 +35mm offset
Do you happen to have a recommendation on tire size? I'll be doing 305/30 on the rear I
Guess 275-285 35 on the fronts??
Old 03-10-2021, 03:14 PM   #230
Zapote21
Tampa Bay Camaros
Zapote21's Avatar
Drives: 2017 Krypton Green 2SS
FR41 5th Gen ZL1 wheels on a 2020 2SS Convertible.
Me and wife, in order
2011 2SS SGM
2013 2SS Hot wheels vert
2016 C7 DSOM
2012 2SS yellow vert
2017 2LT Krypton Green
2018 2LT Hot wheels crush
2020 2SS Shock vert.
2017 2SS Krypton Green coupe
Zapote21 is offline   Reply With Quote
Old 03-17-2021, 08:24 AM   #231
Mortie34
Drives: 2018 Nightfall Grey Metallic 1SS
wheel/tire clearence
Guys i have a 2018 1ss looking at going with the MRR M755 20x10 +23 square setup ...my question is can i run 285/35s all the way around? or will the 35 not clear in the front
Mortie34 is offline   Reply With Quote
Old 03-17-2021, 03:09 PM   #232
It will clear, but it's extremely close to the strut perch, I used 5 mm spacers for peace of mind when I had this size up front.
Tire selection may also impact whether it will rub, I can only confirm that Michelin PS4S tires work, didn't try any other.
Old 03-22-2021, 03:47 PM   #233
NotFast
Drives: 2021 LT1
19x10 FLOW ONE Race Spec F2 BRONZE [square setup]
275/40R-19 Bridgestone Potenza S-04 Pole Position
Roughly 62 pounds total
The fronts barely fit past the suspension - I had my doubts but the Tire Rack was correct.
I bought these wheels in February on clearance and don't think you can find this size any more.
NotFast is offline   Reply With Quote
Old 03-22-2021, 04:30 PM   #234
JitteryJoe
Drives: 21' LTI, '18 Traverse, '15 Mazda 6
Ah so you did pull the trigger on them!
Glad to hear the +28 does fit on the front without spacers that will make me feel better once I eventually order a set (I think they still have these on sale... they had a ton) But I really had my eye on the F5's because they are allegedly 2 lbs lighter per wheel.
Would it be possible to get a shot along the side? Curious to see if they poke out any at all with the larger wheel / offsets? You also wouldn't have happened to weight the wheel/tire before mounting by chance?
JitteryJoe is offline   Reply With Quote
Old 05-03-2021, 02:17 PM   #235
rwise
Drives: 2017 Camaro SS
I recently purchased a 2017 Camaro SS, I am planning on buying the GM lowering kit for it as well at some point.
I am looking to buy 20 inch wheels 285 in the front and 305 in the rear, 1le spec. What offset do people run in the front and the back that would cause no rubbing with the lowering kit?
rwise is offline   Reply With Quote
Old 05-06-2021, 01:52 PM   #236
X-zercist
X-zercist's Avatar
Drives: Chevrolet Camaro 2SS
TSW Brooklands and Continental DWS All-Seasons.
Front wheel is 8.5R20 et25 and rear wheel is 10R20 et35.
Tires are 245/40 front and 275/35 rear.
X-zercist is offline   Reply With Quote
Old 05-22-2021, 09:58 PM   #237
JRodSan
JRodSan's Avatar
Drives: 2021 Camaro SS 1LE
Stance SF07 Brushed Dual Bronze
Front 20x10 et20 285/30
Back 20x11 et40 305/30
https://youtu.be/UcungpxKzaA
JRodSan is offline   Reply With Quote
Old 10-27-2021, 03:08 AM   #238
sspddmn
sspddmn's Avatar
Drives: 2018 ZL1 1LE and 1991 Z28
Going through a lot of trouble to make my old 5th gen ZL1 20" wheels fit my ZLE. New 30 series tires instead of 35. 10-12mm spacers up front and 1in over stock apr extended wheel studs. Open ended lug nuts. Rear driver wire harness relocation. Sigh. Maybe i should have just sold the wheels and get new ones that fit. Was it worth it? Disclaimer: I dont have more photos yet. Still a work in progress. This was just a test fit.
In the garage: 2018 HBM ZL1 1LE // 2013 ZL1 (sold) // 1991 Camaro Z28 5.7L // 2022 Audi E-tron SUV (wife's car) // 2002 Camaro SS (sold)
sspddmn is offline   Reply With Quote
