| View Poll Results: What do you think of the style of the 2015 Mustang? | |||
| Really like it. |
62 | 21.99% |
| Undecided, but leaning positive. |
80 | 28.37% |
| Undecided, but leaning negative. |
69 | 24.47% |
| Don't like it at all. |
71 | 25.18% |
| Voters: 282. You may not vote on this poll | |||
Thread Tools |
#225 |
HTCC Member
I'm going to wait and see one in person before I pass judgement
#226 |
Rice Harvester
Drives: 2014 Bright Yellow 2SS/RS Join Date: May 2008
Basic info (via press release):
Engines 5.0L V8 (Coyote) 420 HP 390 Lb-Ft Sintered-iron forged Boss-like 302 rods and springs Upgrade valvetrain and cylinder heads with improved port design Larger valves and cams New intake manifold with charge motion-control valves Redesigned piston tops Balanced forged crank 155 MPH top speed 3.7L V6 300 HP 270 Lb-Ft 2.L 4 Cylinder EcoBoost 305 HP 300 Lb-Ft Twin-scroll turbocharger Direct injection Twin independent variable cam timing Steel crank 3-port cylinder Dimensions 0.12 in (3mm) longer 0.51 in (13mm) wider than outgoing 2014 Mustang (s197) 1.49 in (38mm) lower roof 0.78 in (20mm) lower seating position Transmissions Updated manual gearbox revised shift linkage for shorter throws / smooth shifting Automatic with paddle shifters (and rev matching) redesigned case with lighter internals Suspension All-new front and rear suspension systems. New perimeter front subframe helps stiffen the structure while reducing mass, providing a better foundation for more predictable wheel control that benefits handling, steering and ride Front MacPherson strut system with new double-ball-joint spindle (allows for larger brakes and improved handling feedback) Rear integral-link independent rear suspension (benchmarked against Boss 302) New aluminum rear knuckles help reduce unsprung mass for improved ride and handling Brakes Three available brake packages V6 Mustangs: 2 piston calipers with 12-inch rotors Ecoboost 4 Cyl Mustangs: 4 piston calipers with 14-inch rotors (standard on GT model) GT Mustangs: 6 piston calipers with 15-inch rotors (upsized 15% from GT500) Technology Launch Control (GT model) Selectable Drive Modes - Console switches to quickly adjust steering effort, engine response, and transmission and electronic stability control settings Normal mode Sport mode Track mode Snow mode Intelligent Access with push-button start to SYNC® and MyKey® Available Track Apps (standard on GT, optional on EcoBoost model) MyColor gauges and new Shaker Pro audio system Blind Spot Information System (BLIS) with cross-traffic alert Adaptive cruise control SYNC AppLink Oil pressure and vacuum/boost gauges Push-button start Tire pressure monitoring system (TPMS) Remote starting and remote window opening options Interior Occupants lowered 0.78in (20mm) More overall interior room Visibility improved More trunk space Rear seat pass-through 40mm wider Rear seats feature more hip and shoulder room USB and 12V outlets Convertible Cloth top and center latch. Top opens and closes in 7 seconds (half the time of the outgoing model) 2015 Mustang colors Competition Orange Triple Yellow Oxford White Deep Impact Blue Ruby Red Ingot Silver Magnetic, Guard Black |
#227 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
So no direct injection for the Coyote and no power bump? That is really strange. I figured it would be direct injected for sure and with new ports, valves and cams, you think there would be some power increase.
#228 |
*new car smell*
Drives: 2007 Ford Mustang 'Natasha' Join Date: Jan 2007
I really like it but I still prefer the previous generation but did not care for the 10-14 model revision of it (except for the interior and the upgraded V6 and V8 engines).
"May the forces of evil become confused on the way to your house."
George Carlin |
#229 |
Force RECON
Drives: 2005 Saab 9-5 2.3T Join Date: Jan 2008
#230 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2ss Join Date: May 2013
Doesn't look bad. Nothing that makes me "got to have it" though.
#231 |
Rice Harvester
#232 | |
![]() ![]() ![]() ![]() Drives: 2010 2SS, 2011 Buick Regal Turbo Join Date: Mar 2009
#233 | |
#234 | |
#235 |
just can't get enough
On Ford website... lots of pics, color choices, & info: http://www.ford.com/mobile/cars/must...hoo#appsimHome
Looks good to me and I like the many features & options... |
#236 | |
#237 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Love the one you're with Join Date: Sep 2009
Wow! The more that comes out the more I'm loving this. The interior is fantastic and the exterior is a very nice progression. I can't wait to see what the top dog versions will be.
#238 |
IG @Brian_ _Self
Drives: 2010 Camaro 2SS M6+17'Tesla Model S Join Date: Nov 2012
Interior looks pretty much the same for me.. but idk
