05-04-2017, 08:07 AM | #211 |
Drives: 2018 ZL1 Join Date: Oct 2011
I'm scheduled for Tuesday . After they sent the new tune The couple times I drove it it's been a blast.
2018 ZL1…Many mods to come
05-04-2017, 08:10 AM | #212 |
I also have the Aeroforce. Very nice gauge. Just keep in mind you will need a 2bar maf adapter to read boost.
05-04-2017, 08:19 AM | #213 | |
May I ask What AFR you are running?
www.jannettyracing.com
05-04-2017, 10:52 AM | #214 |
Certainly, under what condition are you wanting the spec? I watch AFR and Lambda both. I know they are telling me the same result, I just like to see both. So I keep AFR on th stand alone gauge and Lambda on the bottom corner of my nGauge.
2016 2SS/Hyper Blue/M6/NPP/Navi
Forged pistons Custom cut Brian Tooley Cam SW long tube headers 3" stainless mid pipe - Secondary Cat delete - High flow cats Port and polished heads-Double valve springs-platinum lifters & push rods Cam phaser limiter - DOD delete P1SC-1 Pro Charger 3.7 pulley Stage II intercooler 667rwhp 577ft lbs |
05-04-2017, 10:58 AM | #215 | |
05-04-2017, 11:01 AM | #216 | |
Drives: Many C7's Join Date: Apr 2014
05-04-2017, 11:06 AM | #217 |
Your guess early in the build came in very close! I'm the only one with this cam though, I got a custom cut through BTR.
05-04-2017, 11:11 AM | #218 | |
I have seen many different "custom" cams for these things. And all of them landed within a few HP of each other. There is only so much you can do when dealing with factory heads/intake and limitations of P to V clearance. Not saying its bad, they did have different idle characteristics. But all fell within the same HP. (well except ONE that literally didn't gain squat.. guess he ordered the "ghost cam" like the Mustang guys do) Now with a good tire on her, my next guess will be..... 10.4's could be in your future. |
05-04-2017, 11:25 AM | #219 |
WOT in Lambda if you have it, if not in AFR.
05-04-2017, 12:13 PM | #220 | |
05-04-2017, 12:21 PM | #221 |
Yes, I use Lambda often and all tuning was done with that. .86 on the dyno pull.
Last night I was on a street in Mexico and did a long hard pull up to 160's mph area and the lowest I seen for that one was .84 that was under 7.8psi and 6200 area of RPM. The climb from the mid 150's to where I let out was slower than all the rest so I was able to watch my fuel more often there.
05-04-2017, 03:09 PM | #222 |
Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
05-04-2017, 03:33 PM | #223 | |
.86 is 12.65 AFR. That is a lot leaner than I would like to see and explains why you could stretch the fuel so far with your set up. On the dyno .85 is where they seem to make the most power but we run them at .78-.80 for cooling on pump gas especially on long pulls past 1/8 mile. I have no trouble running them at .85 on Race Gas. You have a very nice set up Congrats, and enjoy.
05-04-2017, 03:34 PM | #224 |
I gave them my spec and that's what they cut it too. We made small changes on the lift per his suggestion, but I didn't even fill out their card for them to give me a suggestion. So unless someone else has the same numbers in mind and is willing to talk to several people and explain you don't want to fill their data sheet out online you want to talk about hard numbers you have, I would be surprised if someone else has my cam.
