#211 | |
I used to be Dragoneye...
![]() Wow. ![]() |
#212 | |
![]() ![]() Drives: 1970-1/2 Z-28, 2017 ZL1 Join Date: Sep 2012
On the other hand, I do like the rims and tires. Those will make there way on to my ZL1 as soon as they are available. I would bet that 50% of the 3 second improvement in time is due to the tires alone. If I can get that and not have to put the mutton chops on the front of my car and the ricer wing on the back...I am all in. |
#213 |
SABIO
It's o.k... I quit smoking last week. Still working things out
#214 | |
![]() I'll let you work out your business, then, no criticisms. Keep it up, and congratulations! ![]() If it's any consolation...consider that the weight savings they've achieved by opting to offer manual only, thinner glass, and utilizing DSSV suspension...means the car only weighs about 76 lbs heavier than a 1SS/1LE. ![]() |
#215 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS Join Date: Apr 2013
![]() Here's a very rough Photoshop job. I think it makes the rear of the car look more planted and less tall. It also goes great with the dark wing, dark tail lamps, and dark 3rd brake light. ![]() |
#216 |
![]() Drives: 2016 Camaro RS 1LT 2.0L Turbo Join Date: Apr 2016
Sounds like a lot of guys here just need a 2SS with a supercharger.
They don't like the necessary requirements needed on a high speed track car.
'16 1LT 2.0T RS - Catless DP, Intake, Tune/ Eibach springs FE3 shocks/ BMR front bar FE4 rear bar/ Xpel'd front end, CP Reload sealed/ Radenso Pro M.
#217 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
🔺22 RS E TRON GT
🔺21 Model S Plaid |
#218 |
![]() Drives: 15 1ss 1le Join Date: Jan 2014
So no engineer on the team raised their voice and said... hey zl1 1le sounds stupid, lets just add an r lol. Besides that it looks stupid but im sure it will kick some ass.
#219 |
Maybe they don't want a car that can actually turn? In which case, if you plan to only drive in a straight line, yes there are cheaper alternatives out there.
#220 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
14 Z/28 3,837 lbs 17 ZL1 M6 3,883 lbs 18 ZL1-1LE 3,823 lbs
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
#221 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Have you seen the Viper ACR? This is the same thing.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
#222 | |
As much as I'd loved to see GM through an N/A engine in this car and pull out more weight, its just not in the cards. GM can't hit the HP number's they want (and pass emissions) without a DOHC engine, and its not ready yet.
#223 | |
#224 | |
Drives: ATS4 Join Date: Dec 2016
