#211 | |
![]() Drives: 2016 Camaro A8 2SS w/Maggie Join Date: Dec 2016
Just being dumb. Thanks Ted!!!
#212 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#213 | |
This is Ted's cue to step in and correct everything I just said.
#214 | |
![]() ![]() ![]() ![]() Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
Didn't you say that you also have a jms fuel pump voltage booster? Sent from my SM-G920V using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
#215 |
Drives: Audi S6 V8TT, Volvos XC60 & S60R Join Date: Feb 2016
Ted,
Can a Catch Can be installed on a Centi SC System? How do you route the hoses and vaccum line to the Surge Valve? Thanks once again. |
#216 | |
I hit the fuel supply wall with the 80 mm pulley 11.5 psi boost, our cam headers exhaust on E-85 which put down 726 RWHP 701 RWTQ with fuel pressure dropping at 6400. Switching back to the 85 mm pulley 9.2 psi boot and retune made 725 RWHP 674 RWTQ and fuel pressure held steady till 6800. On high octane gasoline this fuel supply wall will be much higher with the LT4 fuel system and ZL-1 Pump
#217 |
Correct.
#218 | |
Ted.
#219 |
#220 |
Be happy to provide you with all the parts and installation instructions with your supercharger kit when you order.
#221 |
Thanks Ted, I already have a Mishimoto C C .
#222 |
A friend was recently speaking to a local shop in his area about getting to 600rwhp. It was not ADM or any other forum sponsor. If you have any thoughts, let me know. If you prefer not to comment on another shop's statements, I understand:
- The easiest way to get to 600whp on a 6th gen with a SC is to just add a meth injection system. - The next, most reliable, option would be a camshaft kit for the car along with a pulley upgrade. We would remove the DOD/AFM, rebuild the cylinder heads with new valve springs, and most importantly over drive the fuel lobe by about 32% (giving you the fuel bump needed). - We do not recommend changing the OEM fuel system because its more than capable of supporting 850HP, and changing so much of it up only leaves room for future failures, and unreliability. |
#223 | |
I have gone to 575 RWHP on Gasoline and Yes I can easily go over 600 if I add a Meth system. I do not however agree with the other statements. Ted.
#224 | |
