11-22-2016, 04:53 PM | #211 | |
Drives: 2011 Camaro SS L99 Join Date: Jan 2012
11-24-2016, 01:13 AM | #212 |
Drives: 13' 1LE Join Date: Apr 2012
Which AMoils? Signature series and OE oils series do not have the extra zinc. Id like to know since I rarely hear failures with AMoils. Even when running the perfect oil, it doesnt void all risk..
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
11-24-2016, 07:49 AM | #213 |
11-24-2016, 04:45 PM | #214 | |
Drives: 2010 SS L99 IOM Join Date: Aug 2012
I'll read this thread from the beginning for more info in case its in here.
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins |
11-24-2016, 05:09 PM | #215 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
Would this be considered "over camming ", if so, why?
11-27-2016, 06:36 PM | #216 |
Drives: ‘13 1LE Join Date: Jul 2013
XL: Run_of_the_mill Group III base stocks, API approved, to compete with the rest of the off_the_shelf Group3'ers out there
Sure, great oil for any daily driver, but for a performance car with a cam, running at least 50wheel over stock and track driven.....hmmmmm, you have much stouter choices out there, even from Amsoil themselves. |
11-27-2016, 06:42 PM | #217 | |
Thought I'd come and take a break in here. Reading 3 days worth of Podesta emails, and some other Wikileaks related material is quite , this place is refreshing . |
11-27-2016, 06:45 PM | #218 |
11-27-2016, 11:10 PM | #219 |
It is a good oil, but it doesnt have anymore Zinc than other regular oils like standard Mobil one and other regular off the shelf oil.
13' 1LE
11-28-2016, 03:39 AM | #220 |
THE U
Drives: Camaro 1SS/RS Join Date: Jul 2015
Run the 10w30 Z-Rod and love it.
03-04-2018, 07:02 PM | #221 |
SS
stock cam
failure at 10k on new warranty now mobil 5-30 going to a btr stage 3 with reccommended BTR upgrades trunnions springs and pushrods 3 bolt upgrade and a tensioner will track car after 5000 miles oil upgrade and break in oil is what I have gleaned from this scary thread
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
05-28-2018, 11:41 AM | #222 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Vengeance Comp Cam wear
This VSRP II cam was installed in July 2013. It now has right about 23,000 miles on it.
Cam:
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
05-28-2018, 11:48 AM | #223 |
Dan
Cam still in use: No
Cam type/brand: COMP Cam Specs: 227/235 .613/.620 115 Cam miles: 23K Forced induction: NO Power level: About 460rwhp/460tq Oil type: mobile 1 5w-30 or Royal Purple 5W-30 Oil Pump: Melling 10296 Date of cam purchase: July 2013 Valve train upgrades: BTR .660 springs and hardened pushrods stocktrunions Bottom end upgrades: SBE Glad I am changing out cam while going to FI. Two broken pushrod cups and damage to oil pump gerotor - although oil pressure was fine before teardown. Lifters
Dan
10-26-2021, 12:28 PM | #224 |
Drives: 2010 Camaro SS Join Date: Sep 2020
Probably half the people here have sold there Camaro SS, but for the die hards. This what I know about cam failures.
8620 is the ideal core to get a grind on. Lifters play a big role in how long a cam lasts. More important than that IS NEW LIFTER trays!!!! If your camming a 50000mile LS3 and your not changing lifter trays or lifters your screwed. Lifter trays wear out, allowing the lifter to rotate, causing premature wear on the cam. So change them. There only good for max 70 000miles. I put new heads on and went to Johnson Lifters with new GM trays. Cam looked good, nothing crazy, but I know I have to change everything come 20000km on cam and lifters. Just the price to pay to keep things safe. Cam has 15000km and is going strong. Oh and change your oil, max oil interval for my Camaro SS heads cam is max 3000KM, I'm not kidding!!! Good oil is cheap. Black oil will wear your engine out. https://youtu.be/eeb-9zksOeQ |
