#22331 |
ZLT!!! COTW (8/5/13)
Drives: 2011 IOM 1LT RS M6 Join Date: Mar 2012
Bushings/ trailing arms
1) I have the BMR rear suspension bushings and differential bushings, this includes the trailing arms bushings? 2) trailing arms: how changing this helps in the car? I imagine is on handling, more stiff? Jumping guys!
#22332 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
I do not know the answer to question 1 but to answer question two I believe the most common use for trailing arms is to reduce wheel hop under acceleration. I am no suspension expert so I could be wrong.
#22333 | |
Chick Racer
Drives: 2017 50th 2SS Join Date: Dec 2012
#22334 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
Well after I redo the left side it doesn't pull that bad anymore. Now it just does it a little bit. Also now the car like follows every imperfection on the road. I am getting the alignment next WK. The shop I wanna go is closed until Monday so..
Sent from my DROID RAZR using Tapatalk
#22335 |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
Well that is good so the alignment should fix the rest. Plan on lowering my car next weekend! Thinking of lowering it an inch on all 4 corners.
#22336 | |
COTW 9/16/13
.Lol to answer question 2 it does reduce wheel hop and when I replaced my trailing arms with the outer bushings the car felt more planted to me. It seemed to respond better and just go when I hit the gas. |
#22337 | |
thanks for the answers guys! by the way why is so dead here???
#22338 | |
COTW 9/16/13
Lol...no idea |
#22339 | |
The V6 Lounge
Lucky. Whenever I get around to lowering that's what I plan on doing. But requested my time off for the fest today and should be ordering my new HTC One M8 tomorrow. |
#22340 |
Ok so my left wheel still crooked. Its like the camber bolt needs to be loosen up and move out.. I touched the spindle and on the right I can fit a little bit of my finger tip. On the left is against the strut. Alignment will fix that. I am waiting on this to reopen. Good reviews and one-man shop. Will have him index the bushing and alignment
#22342 |
Oh yeah I forgot about winter over there.. I'm glad for u..
#22343 |
I will probably will get the alignment next Thursday Cuz that's my next day off.. I am hoping things get fixes after it. BMR is good stuff thou. No noises no issues with the springs. Ride is almost as the same as OEM.
