Old 06-10-2019, 10:02 PM   #197
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
Originally Posted by Kamaro223 View Post
9,000 miles later and my shudder is back. The severity from when I first felt it to "damn, this is bad" was way quicker than before...like 4 weeks. This car is a joke. This fix is a joke. GM is a joke. I'm done.
Was this with the new flush/fluid TSB GM released?
Azerlazer26 is offline   Reply With Quote
Old 06-11-2019, 09:18 PM   #198
Kamaro223
Kamaro223
Kamaro223's Avatar
Drives: 2016 RS/LT Camaros
I'd have to dig it out and look.
Is the new flush with Mobil 1 or is there a new new flush procedure?
Kamaro223 is offline   Reply With Quote
Old 06-11-2019, 10:01 PM   #199
Azerlazer26
To my understanding it’s just new fluid. Not sure if the procedure has changed.
Old 06-11-2019, 10:57 PM   #200
New flush equipment was also introduced, it is supposed to be able to remove the old fluid more thoroughly.
EDIT: I've found this post to corroborate: https://www.midenginecorvetteforum.c...9969#post29969
Old 06-14-2019, 09:04 AM   #201
NW-99SS
Drives: 1999 Camaro SS M6 - SBE LS1
I highly recommend trying the Range AFM Disabler. Eliminate the TC Pulse solenoid entirely by shutting AFM off. It makes a world of difference in my truck - no more V4 mode and the truck is smooth as silk.
1999 Camaro SS 6M - SBE LS1
1994 Camaro Z28 6M - Golen 383 HT
1963 Corvette GrandSport - ZZ502 4M
2017 Denali 1500 6.2
2017 Yukon Denali 6.2
NW-99SS is offline   Reply With Quote
Old 06-14-2019, 09:10 AM   #202
18ss376
Drives: Camaro
If GM would of put in a ZF 8HP transmission none of this would be happening.
18ss376 is offline   Reply With Quote
Old 06-14-2019, 09:10 PM   #203
Hindsight is 20/20, and they apparently did a better job with the Hydra-Matic 10L90 (none of the ZL1 A10 folks are drooling after the ZF), so it isn't like they can't design a good trans. Wonder if we'll ever find out what exactly went wrong with the 8L45/8L90.
Old 06-15-2019, 10:56 PM   #204
Mick0311
Drives: 2018 Camaro 2SS Redline
My 2SS goes in monday for the trans shutter. Only 1800 miles on the car.
Mick0311 is offline   Reply With Quote
Old 06-17-2019, 06:35 PM   #205
Mick0311
Dealer confirmed the shutter and will get working on replacing the fluids.
Old 06-17-2019, 07:20 PM   #206
Brudda*Termite
Brudda*Termite's Avatar
Drives: 2017 Camaro 2SS
A couple of months after my flush and replace, the car is running perfectly. I don't believe AFM was ever my problem, but I'm deleting that b.s. with a custom tune shortly anyway, hate the "interruption" while I'm enjoying the V-8 version...
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon
Brudda*Termite is offline   Reply With Quote
