Old 12-05-2019, 03:35 PM   #197
Josh/AWE
Josh/AWE's Avatar
Drives: 1LE
Originally Posted by Intimidator View Post
And this is false also...same reasons for me!
With normal startup my car sounds Brutal, there are times I need to quiet it down...I don't want a perfect for all times exhaust. I want Brutal with the ability of stealth.
It's not false just because you don't agree with it, my friend. Just stating the average answer upon customers. NPP is "needed" for some, sure. But certainly not everyone.
Josh/AWE is offline   Reply With Quote
Old 12-17-2019, 01:42 PM   #198
Josh/AWE
Josh/AWE's Avatar
Drives: 1LE
Receive 15% off all AWE Camaro products, valid through participating AWE dealers and AWECamaro.com.
Old 01-30-2020, 12:28 PM   #199
Josh/AWE
Josh/AWE's Avatar
Drives: 1LE
AWE Track Edition Axle-back Exhausts are ready to ship. Learn more right this way.
Old 01-30-2020, 03:38 PM   #200
PROMETHEUS
PROMETHEUS's Avatar
Have this setup with the Performance Link Pipes for about 8 months. No issues and no CELs. Love the sound they make and the install is doable in your garage in a couple of hours with the car up on jack stands. Highly suggest a 2nd set of hands, but can be done alone.
Old 01-31-2020, 08:53 AM   #201
FoundNemo
Drives: 2019 ZL1
Need clips of the AWE Touring Resonated Camaro exhaust before I would consider buying!
FoundNemo is offline   Reply With Quote
Old 01-31-2020, 09:48 AM   #202
PROMETHEUS
PROMETHEUS's Avatar
I believe AWE has several videos of their camaro on their website.
Old 02-01-2020, 11:58 PM   #203
Doc_Scott_PT
66,144 hrs in the making
Doc_Scott_PT's Avatar
Drives: 2021 ZL1 Riverside Blue
The unicorn exhaust note:
-Kooks headers, Green cats
-AWE Touring cat back with resonator
Cannot find it ANYWHERE.
Doc_Scott_PT is offline   Reply With Quote
Old 02-02-2020, 07:51 AM   #204
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Any header w/cats setup will give you what you're looking for. You dont really get different sound from different brand headers, all other things remaining the same.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 02-02-2020, 10:43 PM   #205
Doc_Scott_PT
Fair, but set ups with headers, touring, and resonator, with cats doesn't exist or I haven't found one after scouring the interwebz. haha
Old 02-07-2020, 04:59 PM   #206
Josh/AWE
Josh/AWE's Avatar
Drives: 1LE
Performance Link Pipes, or no Performance Link Pipes?
Get details on the option-packed AWE Exhaust Suites for the Gen6 Camaro SS and ZL1 right this way.
Old 02-13-2020, 03:01 PM   #207
Sara/AWE
Sara/AWE's Avatar
Drives: Camaro
RevOff: C7 vs Gen6 Camaro SS 1LE with our Tourning Edition exhausts. Who will reign mightiest in this brotherhood rivalry?
Sara/AWE is offline   Reply With Quote
Old 02-14-2020, 09:44 AM   #208
Crushed 1LE
Crushed 1LE's Avatar
Drives: 2022 ZL1 1LE
Josh, there have been some rumblings of the PLPs causing false knock. Can you please comment on this? That being said, I have yet to see a data log showing this. Perhaps you guys have some data on this. Thanks Herb.
Crushed 1LE is offline   Reply With Quote
Old 02-14-2020, 09:52 AM   #209
FoundNemo
Drives: 2019 ZL1
Links for any 2nd cat deletes causing false knock. FYI a resonator (and ensuring no leaks) in that cat location may eliminate the false knock issue but not yet tested:
https://www.camaro6.com/forums/showthread.php?t=508279
https://www.camaro6.com/forums/showthread.php?t=467330
https://www.camaro6.com/forums/showthread.php?t=475600
https://www.corvetteforum.com/forums...uestion-2.html
Old 02-17-2020, 09:40 AM   #210
Josh/AWE
Josh/AWE's Avatar
Drives: 1LE
We have never experienced this before. I would ensure connections are tightened down and secure.
