07-26-2019, 02:06 PM | #197 |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
Forgive me if I ask a redundant question but reading through this thread usually leads to my mind drifting off to something other than the reason I'm reading with the wealth of info available in this topic
I've only just discovered that Sport mode with the nannies shut off is really the only place you want to be in order to launch the car with full tire spinning bliss My question is, what is the difference between being in Sport mode.... and a double click of the Traction Control switch compared to a press and hold of the traction control switch for 5 seconds or so? Both turn on the TC disable and STAB disable lights, but the double click also shows Comp mode on the readout. So whats the diff? Can anyone explain? |
07-26-2019, 02:23 PM | #198 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Yep: please read the very first post of this thread.
All the info is there. Cheers! |
07-26-2019, 02:44 PM | #199 | |
Let me ask a different question....If I wanted to COMPLETELY shut off all nannies, say to drift the car without any type of Stabilitrak or E-LSD kicking in ...what mode would you choose? Because I'm not seeing an option for that. |
07-26-2019, 03:11 PM | #200 |
Drives: 2019 ZL1 1LE Join Date: Jul 2019
Hello, long time reader, first time poster.
I know we didn't buy our 1LEs to go drag racing, and I doubt I will do so, but I do have questions about Launch Control as some of the events I "compete" in (and I use that term very loosely) have a Launch Box/Stop Box event where I think it would be handy. I cannot find Launch Control in my '19 SS 1LE. I sat there for a half hour pouring through menus and setting combos, never see the option in the DIC like the manual shows for Launch Control. What am I doing wrong? Thanks! Last edited by White_1LE; 07-26-2019 at 03:45 PM. |
07-26-2019, 04:18 PM | #201 | |
07-26-2019, 04:21 PM | #202 | |
And trust me you can then drift the car (assuming you have sufficient talent for it ). Cheers! |
07-26-2019, 06:38 PM | #203 | |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
07-27-2019, 01:49 AM | #204 |
I followed the directions from the HP Supplement from page 26. It states to reference "Custom Launch Control" in the main Owner's Manual, which I did and found that section starting on page 176. But the menu shown on page 177 in the Options section for Launch Control in the DIC is simply not there at all.
I tried all of the PTM modes within Track mode as well as Competition Mode in Sport. I followed the directions and had the parking brake off, steering wheel straight, doors closed, tried clutch out in N and clutch in in 1st. Nothing. Do SS 1LEs not have "Custom Launch Control" but have some other version of Launch Control that is not configurable? I spoke with a gentleman with an '18 ZL1 1LE and he said he has those menus and can configure his Launch Control settings. Still confused... |
07-27-2019, 05:44 AM | #205 | |
07-27-2019, 07:40 AM | #206 |
Thank you for your answer, I'll file that away for an empty parking lot one day
07-27-2019, 07:41 AM | #207 | |
As yotaman said, it's not customizable. You just hold the pedal to the floor and the revs will climb up and then back down and settle at 3500 I believe. Than just feather the clutch as much or as little as you want when launching. |
07-29-2019, 09:13 AM | #208 |
Thanks guys. That is what I figured from what I was seeing.
Mine settled down to about 3000 rpm. Definitely feels better launching without using it in Sport - Competition Mode. Maybe more practice will help. |
08-08-2019, 12:39 PM | #209 |
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M Join Date: Jul 2019
Thank you OP. Very informative.
08-08-2019, 02:09 PM | #210 |
