Old 05-01-2017, 04:49 PM   #197
Summit1le1ss
Drives: 2017 1ss1le
Awesome! Totally understand being short on time. Will you make a how to thread once you have it sorted out? I might opt for a seat mounted switch solution to avoid buying a whole new control panel if the seat heat/vent buttons can't be simply added to our stock setup.
I definitely will. "Simple" isn't a word I'd use right now, hence wanting the control panel.
Summit1le1ss is offline   Reply With Quote
Old 05-01-2017, 08:17 PM   #198
Camaro6717
Drives: 2017 Camaro 1LE
I had found one in a junk yard for around $115 shipped but now it's sold. Here's one on eBay, a lot more but at least it's available.
http://m.ebay.com/itm/16-2016-Camaro...053?nav=SEARCH
Camaro6717 is offline   Reply With Quote
Old 05-02-2017, 07:24 AM   #199
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
If I did go the route of the whole control unit will I also get functional dual zone climate control or does that require additional external parts?
Old 05-02-2017, 08:54 AM   #200
TJay74
Requires additional parts
Old 05-02-2017, 12:02 PM   #201
Summit1le1ss
Drives: 2017 1ss1le
Correct.
Requires one additional temp sensor, harness and the Evap box itself is different.
All parts are available. About $200.
I never use auto anyway, so not concerned.
Old 05-02-2017, 12:25 PM   #202
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Correct.
That might mess with my OCD LOL! You think seat mounted switches will be an option for both heat and vent if desired?
Old 05-06-2017, 12:24 PM   #203
Summit1le1ss
Drives: 2017 1ss1le
3rd time was the charm. Finally got it.
Should have a little time tomorrow to test out the controls and harness. Unfortunately a good deal needs to come apart. Radio, center console and front of dash.
Old 05-06-2017, 01:04 PM   #204
WhyUMad1LE
Drives: 17 SS 1LE
Congrats. What does the back of the unit look like? Are there plugs behind the heat/cool switches?
Old 05-06-2017, 01:12 PM   #205
Summit1le1ss
Drives: 2017 1ss1le
No, it's the same 10 pin connector used in all Camaro models. The HVAC mod is the same also. In theory it should communicate the exact same way.
Old 05-09-2017, 11:54 AM   #206
TransAmx2
TransAmx2's Avatar
Drives: '98 Pontiac Trans Am
I don't even own a 1LE yet and I'm glued to this thread and it's development. I wish I had one so I could help contribute, but I'm about 5 months out.
Keep up the good work.
2017 1LE Camaro Hopeful
1998 Trans Am M6, Bolt Ons (Daily Driver)
2005 Eddie Bauer Expedition (Family Vehicle)
2007 Z51 Corvette M6 (Salvage Project Car)
1987 Trans Am 350tpi A4 RIP
TransAmx2 is offline   Reply With Quote
Old 05-14-2017, 10:42 AM   #207
Summit1le1ss
Drives: 2017 1ss1le
Update:
It works. Not so simple. The circuit board has to be changed to have to fan speed work correct. This involved trimming the rubber under it.
The screen for fan speed also needs to be swapped as it reads in numbers and the screen didn't. The switches for the seats need to be moved to our control panel.
I have the passenger side heat and vent working. Have to add several wires about 10 from pass to drivers to get that working. I don't have correct terminals for the body harness, so waiting on those.
Everything is ran from the correct circuit to insure no problems.
Here are a few pics I've taken to give you an idea of the swaps. I will do a complete parts list and more in detail write up soon.
Heat is awesome. Gets pretty warm pretty fast. Vent, yes, you can feel and if put the AC to floor makes getting in your car at 100'f a bit nicer. Again, drivers side isn't hooked up yet.
Old 05-14-2017, 10:58 AM   #208
The_Coleman
Drives: 2017 NGM 1SS 1LE
Oh yessssss!!!!
I will definitely be doing this, can't wait to see the finished product!
The_Coleman is offline   Reply With Quote
Old 05-14-2017, 11:07 AM   #209
HalfMoon
Drives: '18 JLU Rubicon, '19 Golf R
Update:
Heat is awesome. Gets pretty warm pretty fast. Very, yes, you can feel and if put the AC to floor makes getting in your car at 100'f a bit nicer. Again, drivers side isn't hooked up yet.
Outstanding!
Looking forward to the final write up.
HalfMoon is offline   Reply With Quote
Old 05-14-2017, 11:09 AM   #210
Summit1le1ss
Drives: 2017 1ss1le
Bit more involved than I hoped... But, hey, nothing ventured....
Have a lot of pics to organize.
