Old 04-25-2018, 03:21 PM   #197
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by Childs Play View Post
How do I tighten this part? Or should I have someone else who knows what they're doing climb under there?
If I were you I would take it to a shop at this point?
Pollock is offline   Reply With Quote
Old 04-25-2018, 11:02 PM   #198
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
I still have the clunk going over bumps sometimes and can feel it through the wheel. I'm wondering if this is what's causing it. I've already swapped to aftermarket end links and added nordlock washers and loctite.
I had my car aligned not too long ago but notice that the wheel randomly likes to be off center some times as well.
Now here comes the dumb question...
A steering angle sensor reset needs to be done.
https://www.hunter.com/about-hunter/...e-sensor-reset
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 04-26-2018, 09:17 AM   #199
Gunmetalmissle
Drives: 16 ngm ss
Per corvette forum the gm threadlocker is permatex 27200. This is high temp high strength red. Thought I would mention since it was suggested several times in this thread to use blue.
Gunmetalmissle is offline   Reply With Quote
Old 04-26-2018, 10:14 AM   #200
harrist5683
harrist5683's Avatar
Drives: 2018 Black ZL1 A10
My 2018 ZL1 with ~2400 miles started experiencing this issue. Have never tracked the car, but I use it as a daily.
I had them apply PIC6276 (tighten endlinks) while I was waiting for the parts for PIC6276B (replace endlinks). No further issues so far.
Current Car:
2018 Camaro ZL1 | Black | A10 | PDR | Nav | Sunroof | CF Hood Insert | CF Instrument Panel
Mod List:
Corsa Extreme Axle-Back | Borla X-Pipe (#60607) | Roto-Fab CAI | GM Dark Tail Lamps | GM Dark Third Brake Lamp | DD Dark Side Markers | GM CF Fuel Door | Rear Reflector Blackout Kit | Xpel Clear Bra | Modesta BC-08 Ceramic Coat
harrist5683 is offline   Reply With Quote
Old 04-26-2018, 06:51 PM   #201
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Unless you have bent components and setting toe puts the sensor out of range there is no need to reset it. All alignment angles are dynamic, they change as you drive. You turn the wheel to the left, go over a bump with the right wheel and so on. The computer in the car 'knows' this or the steering angle sensor would need to be constantly reset.
If the inner tie rod is loose, you could tighten it but it would be better to have an alignment done to bring everything into spec.
JusticePete is offline   Reply With Quote
Old 04-26-2018, 11:17 PM   #202
camaro5
camaro5's Avatar
GM says reset if after any alignment.
If the toe is adjusted it needs to be reset for sure.
Normal dealer alignment procedure is to "set the toe and go"
Also, if this isn't the issue, why is his steering wheel not centered sometimes?
What's your diagnoses and repair?
Steering Angle Sensor Centering
The steering angle sensor does not require a centering often. Centering of the steering angle
sensor might be required after certain service procedures are performed. Some of these
procedures are as follows:
Wheel alignment
• Steering gear replacement
• Steering column replacement
• Steering angle sensor replacement
• Collision or other physical damage
• Electronic brake control module replacement
k
STANDARD DISCLAIMER
Old 04-27-2018, 07:20 AM   #203
JusticePete
• Wheel alignment
k
Depending on our work load, some days my setup and alignment equipment are deployed trackside. On those days we use the alignment rack at our local GM Chevy Dealer. To be clear we work with their best Tech, a super guy, or do it with my guys. In three years. We have reset one sensor because it was bad. Over the last 14 years a handful.
Why does his steering wheel change, something is loose, worn or broken.
FYI #1 The Steering Angle Sensor has no mechanical influence on the position of the steering wheel.
FYI #2 If the sensor is out of range, it puts the car in reduced power mode.
Old 04-27-2018, 07:22 AM   #204
JusticePete
• Wheel alignment
k
Note the wording 'MIGHT be required"
Old 04-27-2018, 09:05 AM   #205
Childs Play
Pizza & Wings Only $12.99
Childs Play's Avatar
Drives: 2017 Camaro SS
Oh I've taken it to the dealership plenty of times. Finally I gave up and put aftermarket endlinks and nordlock washers on. Clunk still came back for a while. I haven't heard it recently though. That's why I was wondering if it was the part he mentioned... Since I've done the fix and still have intermittent issues.
H-Town Camaro Club
Past Rides:
2012 Camaro 2SS/RS M6
2012 Camaro ZL1 A6
2017 Camaro 2SS M6
Childs Play is offline   Reply With Quote
Old 04-27-2018, 04:04 PM   #206
camaro5
camaro5's Avatar
#1 Why does his steering wheel change, something is loose, worn or broken.
#1 This isn't the first Camaro with this issue; Visual inspection is required, but I'm saying low probability to worn, broken, loose.
If Childs Play gets a scanner, he could do the reset himself, easily.
#2 As long as the fault lasts long enough.
The steering angle sensor centering procedure can be preformed with a scan tool in the
automated center procedure by the following:
1. Using the steering wheel, align the front wheels forward.
2. Set the transmission in the PARK position.
3. Install the scan tool to the data link connector (DLC).
4. Turn the ignition switch ON, with the engine OFF.
5. Select Vehicle Control Systems/Module Setup/EBCM/Steering Pos. Sensor
Calibration.
6. Follow the scan tool directions to complete the automated centering procedure this
should include turning the steering wheel left 5 degrees and right 5 degrees and
then straight forward.
7. Clear any DTCs that may be set. Perform the Diagnostic System Check to verify no
current DTCs. Refer to Diagnostic System Check - Vehicle .
8. Centering of the steering angle sensor is complete.
STANDARD DISCLAIMER
Old 04-28-2018, 10:31 AM   #207
Pollock
LT4 M6
Pollock's Avatar
Originally Posted by Bx Tpr View Post
I def get feedback when it clunks. Initially I thought there was an issue with the steering rack but that wasn't the case. I've been trying to figure out how to get a torque wrench on the bottom nut with the limited space available with no luck. This sound is driving me crazy.
I found my upper drivers side to be loose. And getting anything other than a closed end wrench on the bottom is all I can do myself. Since the bottom is tight I'm not going to mess with it for now.
Old 04-28-2018, 07:58 PM   #208
Bx Tpr
Drives: 22 ZLE 6MT
This is what I was experiencing myself with nordlok washers and red loctite. I wouldn't hear it for a few days then it would come back. I took the endlink off finally and the noise was still there. I'm having the dealership look at the steering rack next week just in case there's and issue with the inner tie rod being loose or worse.
Bx Tpr is offline   Reply With Quote
Old 04-29-2018, 07:22 PM   #209
Badmojo
aka BeastZL1
Badmojo's Avatar
My ZL1 is a 2018 (Nov 2017 build date) and it looks like GM may have made some changes. The lower sway bar links are marked with blue paint to see if they move. I have 2300 miles with an hour on the road course. They were tight.
I will continue to monitor.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 04-29-2018, 08:11 PM   #210
Pollock
LT4 M6
Pollock's Avatar
Mine was built in June 2017 and had the blue paint also.
The links design with only one nut to torque and the other side no way to hold it is the problem I think. It was rather tricky to get mine torqued to spec. I can easily see a worker with no attention to detail not getting these endlinks tight correctly the first time.
