#197 |
#198 |
![]() ![]() ![]() Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Strong pull, I'm sure you must be pleased!
#199 |
I'm very happy! It runs strong. Saturday we made 2 passes, let it sit and cool off then made two more passes. Every graph laid within one or two hp/tq numbers of each other. It actually peaked at 672hp, but it was a rarity and the 667hp number we consistently hit.
#200 |
![]() Drives: 2016 Camaro 2SS M6 Join Date: Mar 2017
Right at 2800 I hear it start to spool up. You?
715whp/665tq
#201 |
I don't show it on the gauge until after 3k. Technically your pro charger is always spooled up, the bypass opens at low rpm and dumps what the blower is making then closes and allows the boost to go to the engine.
#202 | |
![]() ![]() ![]() Drives: 2018 ZL1 Join Date: Oct 2011
2018 ZL1…Many mods to come
#203 |
Well, I throw down too VERY NICE, great job, outstanding numbers
#204 |
#205 |
#206 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
Great work. I bet it is a blast to drive. So you are just fuel lobe and meth right now for fuel correct?
#207 |
No meth at all, fuel lobe on my cam and everything else is 100% LT1 stock. This is on pump gas 93 octane. Only dropped 2psi on the low side and nothing on the high side. Injectors never got close to 6ms. There is still room in my fuel system for more, it's not even showing signs of leaning out.
#208 | |
#209 |
It has really made the difference in getting past the stock limitations of fuel. The LT4 HPFP post such good numbers because the LT4 cam has a raised fuel lobe. I don't think anyone has spec'd the LT4 pump on the LT1 cam, or an LT1 cam on a raised lobe.
#210 | |
EDIT::: What gauge(s) do you run? Im in need of getting some. I know i need AFR/Boost, fuel pressure. I saw that lethal bought aeroforce but im curious if there is anything else people are using. Thoughts on AEM FAILSAFE WIDEBAND?
715whp/665tq
