#197 | |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
I'm putting my $ on the fact that GM didn't want to BS anyone or get called out with a "but you said............." The quote was "AT LEAST 200 pounds" If that turns out to have an * in it that means "excludes 1SS, 2SS and 1LE models, direct comparison to V6 models does not apply" then GM is simply playing games with themselves. I don't believe this to be the case however. The "AT LEAST" may also simply be the cover that there simply is no longer an apples to apples comparison. There may be more standard equipment for example that would make it harder to compare. I do believe the "AT LEAST" means V6 to V6 or SS to SS and the base car with a 2.0T (has that been announced to even be in the program ) would weigh even less.The issue is not many on this website really care that a 2.0T weighs 3,500 pounds. What most care about is the SS weighs less than the Mustang GT and that is outperforms the GT. So just like the HP will be announced as "AT LEAST........." I think the weight is the same. It frankly wouldn't surprise me if the base LS came in closer to 300 pounds less. Although that would be nice........................no one here will car much unless the SS comes in 200 pounds less 1SS to 1SS. But as I've suggested, everyone should go to a Cadillac dealer and sit in the awesome ATS. It is not a big car. If I shot a picture of the ATS sedan in my garage right now sitting next to an SS which is ZETA based you would be quite shocked. And those cars are only about 450 or so pounds apart.
#198 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: camaro Join Date: May 2013
I just drive around with less than a 1/4 tank of gas....a savings of 138 pounds!
Hyperblue/JetBlack |
#199 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
On the caption under the instrument panel piece it also had this little quote that many have overlooked. "Changes like this help reduce total curb weight for the new Camaro by more than 200 pounds."
The Bird is the word! |
#200 |
BigShow
Drives: 2017 1 Camaro + Chevy Avalanche Join Date: Oct 2014
"... the team pared more than 200 pounds off the Camaro.."
I'm taking that to mean that when comparably equipped the V6 and V8 will lose at least 200 pounds. That might mean the the V6 loses 230 pounds and the V8 loses 201 pounds or vice versa. To me anything other than that interpretation would be less than truthful and would not generate good will. |
#201 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 1LE Join Date: Feb 2012
Can we apply a common sense approach to this? Hear me out. A LS currently weighs approximately 150 lbs less than an SS currently right? Is it in anyway possible that a T4 could weigh 200 lbs less than the V6 car?
So to compare anything other than equivalents would make no sense. To advertise 200 lbs between the V8 5th gen and V6 or T4 6th gen would be pointless. All of that effort and to save 50 lbs? Advertising 200 when it was just 50? The only way you put out 200lbs is if it is somewhat comparable models (trim levels will most likely have new equipment so an exact apples to apples may not be possible). Even Ford did not lie on the trucks. May have been a little skewed, but it was true. I don't see GM creating this much hype for it unless it's somewhat across the board options excluded. I only say options excluded because if Mag ride is an SS option, it will negate the weight savings. I would not be surprised if the Hi-Po options use more composites to negate the weight of the bigger heavier power train. My guess is base models get more standard steel/aluminum parts. SS and above start getting more and more composites. I would not be surprised to see CF on the Z models.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013 |
#202 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
OMG people....a 2016 SS will weigh at least 200lbs less than a 2015 SS similarly equipped.
I'm willing to put my $$$ where my mouth is if anyone wants some action (I hope this doesn't break a rule...sorry in advance) |
#203 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 F150 Join Date: May 2014
I don't think the above scenario is the case. I also think that it lost 200 pounds from trim to trim.. |
#204 |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
The ATS's size and weight are no longer a factor in this. GM has said that the Camaro will be different in size. So a difference in weight, as well, only stands to reason. Regardless, I fully expect a 200lbs loss, apples to apples. The ONLY THING that makes sense if you read the info. Anything else would be misleading- deliberate at this point as the car should be locked in by now and they KNOW the production weight.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: 22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
#205 |
I want a 3700 pound Omega based Camaro. That is all.
#206 |
I also just read that the omega platform CT6 is expected to be 7-series BMW sized and only weigh 3700ish. Granted, more premium materials, but GM clearly knows how to shave weight with their new architecture.
#207 |
![]() Drives: Sedan Join Date: Mar 2015
#208 |
Funny you posted as I was typing. If they can get the omega platform to 3700, no reason the smaller Alpha can't.
#209 |
#210 |
2016 Camaro weight is at least 200 pounds lighter than 5th gen (March 30 update)
The Camaro is on a bigger Alpha. The Omega is a full sized platform. Completely different than the Alpha
