05-25-2016, 03:19 PM | #197 | |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
I remember way back when the Gen 5 Z28 was coming out that they mentioned that the carbon ceramic brake rotors developed for the Z28, were also to be used on the upcoming C7 Z06. It is interesting that the size of the Z28 and C7 Z06 rotors are 15.5" on the front (ZR1 also) and 15.3" on the rear (ZR1 was 15").
05-25-2016, 03:20 PM | #198 |
Drives: 2014 2LS (traded in) 2015 1SS 1LE Join Date: Apr 2015
OK so they took parts off cars that cost arpound 20K and put together a car that lost 20K per unit? Something isn't adding up there.
05-25-2016, 03:50 PM | #199 | |
Drives: Current Camaro-less Join Date: Jul 2014
If you open the document in question, you'll see it's dated June 2015. |
05-25-2016, 03:59 PM | #200 | ||
Drives: 21 Bronco Join Date: Jun 2012
05-25-2016, 04:24 PM | #201 | ||
Drives: Boxster GTS Join Date: Oct 2015
Spare me the marketing BS now. The Z/28 tanked. CAMARO sales have not improved AT ALL even with this mythical Q rating (that you continually refuse to source) bump that you claim the Z28 provided, therefore your assertion that it has helped the brand is complete and utter garbage. If you're the expert you say you are, you will disprove the above and you'll do it with evidence. If you don't respond or say it's not worth your time, you'll have made it clear that you are fraudulent. Quote:
Come on. Be consistent. Be factual. |
05-25-2016, 04:25 PM | #202 |
Ford used just as expensive equipment, just different choices. They tested the GT350 with CCB's (as seen on shots of the GT350 prototypes running the ring) but didn't go with them for production.
The carbon fiber wheels are something like $3,000 each retail, so probably around $2,000 cost..that's $8,000 right there..roughly what CCB's would be on a GT350. So, instead of going with CCB's to enhance braking and lower weight..they went with the CF wheels to achieve roughly the same results with conventional brakes. |
05-25-2016, 04:44 PM | #203 | |
Drives: 1970-1/2 Z-28, 2017 ZL1 Join Date: Sep 2012
Q Ratings of companies are highly held intellectual property and are not generally publically available. However, being in the industry for over 20 years and knowing those that have access to these score provides me a unique view of how marketing campaigns, products, and customer relations affects these scores. GM's score has been steadily increasing and Camaro's leaped double digits in the 2012-2014 timeframe. Call me a liar. I could not care less but for those that have the ability to understand more than what they see....the Z/28 was a huge success for GM and if it competes at the same or higher level, another Z/28 (costing more) would most likely continue to build on the success of the previous model. Thus GM is doing what makes sense in the market, if not in your head. Last edited by mkorgan; 05-25-2016 at 04:55 PM. |
05-25-2016, 04:50 PM | #204 | |
Sent from my SAMSUNG-SM-G920A using Tapatalk
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
05-25-2016, 05:11 PM | #205 | |
I know what I don't know, hence why I'm asking the questions. You're doing nothing to answer them put spin your little head around, while managing to be downright condescending. I'm not trying to be contrarian. I don't care about how well/poorly the Z28 did or does. I am trying to understand why, as you claim, an increase in Q rating for the Camaro brand makes a difference if it doesn't translate in increased sales. I question your credentials since you seem so unwilling or unable to explain your statements. |
05-25-2016, 05:28 PM | #206 | |
They're either losing money on each R or they got a super screaming deal, yes. |
05-26-2016, 05:30 AM | #207 | |
I am growing weary of this conversation as it seems no amount of evidence (whether it be VIR times, retail price to build, or Q rating data) will change the mind of those who are bitter that GM built the Z/28 the way they did in the Gen5 Camaro. I for one (with a few others) get it and are happy to see GM continuing to build on a good thing. And with that, I am done. Thanks for the participation. |
05-26-2016, 06:14 AM | #208 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
The ultimate evidence as to whether or not GM was disappointed with the gen5 Z/28 will be the gen6 Z/28. If it is a similarly high cost, track focused car it will be clear they felt they got what they wanted from the program. Reuss has already hinted (below).
Regarding cost, some need to accept the Z/28 wasn't built for them. Camaro has surrendered the mullet demographic to Mustang Quote:
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
05-26-2016, 07:22 AM | #209 | |
05-26-2016, 07:24 AM | #210 | |
I used to be Dragoneye...
I'll be honest, I had to come to terms with this myself. I wanted nothing more than to drive a new Camaro with the Z/28 badge on it. But I did not want, nor could I reasonably afford the 5th-gen Z/28. It's awesome. It's a performance bargain. But It's not for me. |
