View Poll Results: Who has experienced an oil pump failure? | |||
2016 or earlier | 20 | 13.79% | |
2017 | 53 | 36.55% | |
2018 | 67 | 46.21% | |
2019 | 2 | 1.38% | |
2020 | 2 | 1.38% | |
2021 | 1 | 0.69% | |
Voters: 145. You may not vote on this poll |
Thread Tools |
08-26-2019, 09:56 AM | #197 |
Drives: 2018 ZL1 , 2020 GMC AT4 Carbon Pro Join Date: Apr 2019
In my mind, that's a good indication of just how bad and unreliable these pumps truly are. They're not making it very far from the assembly line before they go. If I were GM, I would be very worried that someone will lose power or need to shut down the car at the wrong moment and it will cost them their life. Obviously this is not a rare occurrence.
08-26-2019, 10:00 AM | #198 |
Drives: 2018 hyper blue ZL1 1LE Join Date: Nov 2018
So I am one of those that have modified my car. I am an October 17 build date and know a fellow zl1 owner who's oil pump failed. My previous cars were Porsches and had an oil starvation issue on track days. The simple solution was to install an accusump system. Now with the Porsche it was only a momentary drop in oil pressure, not a pump failure. But, the accusump would add 1-2-3 quarts when it detected a low pressure event. I am considering installing one as insurance on my zle. It would introduce oil under pressure in there event of a pump failure. My thought is that it wouldn't save you from having to r&r the oil pump, but it might very well save the motor.
08-26-2019, 10:34 AM | #199 |
Drives: 2018 ZL1 Garnet Red A10 Join Date: Mar 2015
March 18 build date here--only 3700 miles, so far so good. Fingers are crossed I have escaped the date range from which the most failures were occurring.
2018 ZL1 Red Hot A10 (SOLD 1/21)
2001 Corvette Z06 Quicksilver Heads/Cam/Longtubes 443rwhp (SOLD 5/23) 2018 ZL1 Garnet Red A10 (BOUGHT 2/23) |
08-26-2019, 11:33 AM | #200 | |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Keep in mind that this seems to only affect ZL1's built between 4/2017 and 11/2017. GM has revised the part number for the oil pump something like 6 times, and I don't believe it was an issue after the mid-November 2017 build dates.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
08-26-2019, 03:54 PM | #201 |
Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
Are you sure they revised it? I don't think they did. I can go find my invoice for the part number but I think I checked when it happened and it's the same part number.
08-26-2019, 05:30 PM | #202 | |
edit - Screw it... 12686434 - Found on Les7311's post here. This seems to be what is a current part as of just two months ago. 12677142 - Found on cornerjunkie's post here 12673985 12666738 12665357 12661760 12661207 12659936 12658377
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE Last edited by AZ_1LE; 08-26-2019 at 05:49 PM. |
08-27-2019, 04:46 AM | #203 |
Drives: 2017 Chevrolet Corvette Z51 Join Date: Aug 2019
Have these dates been confirmed at all? The car I'm looking at purchasing right now has a build date of 12/17. After the problems I had with my C7, I really don't want to go through it again with it any car.
08-27-2019, 08:09 AM | #204 |
Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
2018 ZL1 A10 9k miles
Oil pump shattered, took out the entire motor GM covered under warranty, no questions Provided extended warranty that goes with car, traded it in. Build date on the car was 7/17
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
08-27-2019, 10:32 AM | #205 |
The latest build date I've seen on the forums with an issue was 11/17. No confirmation anywhere that I've been able to find, but most of them seem to be from July and October.
Old: 2017 SS 1LE
08-27-2019, 02:08 PM | #206 |
Drives: 2018 ZL1 Join Date: Sep 2017
Ugh.....mine is 08/17....this scares the shit out of me. I am going on 8k miles now.
08-27-2019, 02:14 PM | #207 |
I'm with you brother. I'm at around 14K, with below mods. Wondering is oil weight has anything to do with it. I use 0/40
ARH 2" Long system to stock suitcase / VVT3 cam/ RotoFab Big Gulp/ IW Balancer with 9.1 Ring/ Stock Upper/ HD Belt/ NGK Plug Set/ Taylor Wire set with Head Shields/ Tuned at Lashway Motorsports
08-27-2019, 02:24 PM | #208 |
Drives: 2018 ZL-1 Join Date: Jan 2018
08-27-2019, 03:29 PM | #209 |
Drives: A10 LT4 Join Date: Aug 2016
Any reports on the early 17's letting go?? I took delivery in early-mid March right when it states they went south & don't recall the actual build date.
08-27-2019, 05:02 PM | #210 |
