Old 09-30-2019, 05:47 PM   #1975
kd7895
Drives: 2022 ZL1 1LE
2018 1SS 1LE
Best time so far:
Tires used on the pass: OEM Goodyears
Performance Mods: LT, Borla w/ cats, Rotofab, PI, PTB, E85 & Pray Tuning
R/T...........099
60'.............1.913
330'...........5.143
660'...........7.747
660’ mph...95.21
1000'..........9.980
1320'..........11.862
1320’ mph…120.21
Name of the track: South Georgia Motorsports Park
Date of pass: September 28, 2019
Weather conditions: 79*, 30.09, 68%, 1750 DA
kd7895 is offline   Reply With Quote
Old 09-30-2019, 09:43 PM   #1976
Camaros & Coffee Norcal
Camaros & Coffee Norcal's Avatar
Drives: 2013 Camaro 1SS & 2015 Camaro SS
Tires used on the pass: Toyo Proxes R888R's (Stock wheels)
Performance Mods (if any): CAI, E30, PCM & TCM Calibration
Category submitted for: ZL1 Bolt-ons no internal mods
R/T .302
60' 1.743
330' 4.781
660' 7.194
660’ mph 102.29
1000' 9.258
1320' 10.998
1320' 129.94 mph'
Name of the track: Sacramento Raceway
Date of pass: 9/29/19
Weather conditions:
856 Feet.
Humidity 29%.
Elevation27 Ft.
Pressure 29.87in
Video:
http://bit.ly/2o1aNzP
Camaros & Coffee Norcal is offline   Reply With Quote
Old 09-30-2019, 10:14 PM   #1977
laynlo15
Drives: 2022 Lt1 A10
Nice pass Norcal. Go get em
Old 10-01-2019, 08:23 AM   #1978
grampa_ss
grampa_ss's Avatar
Nice run. 1st gear shifted way too early though.
Old 10-02-2019, 04:33 PM   #1979
phaedrus
phaedrus's Avatar
Drives: 2018 Camaro ZL1 Convertible, M6
Fastest M6 ZL1? And it's a Vert
After being stuck at 11.0 for a while on a slow track, finally cracked the 10s in my 2018 ZL1 M6 Convertible.
Tires used on the pass: MT ET Street Drag Radials - 325/50/15
Performance Mods (if any): Cam, CAI (Rotofab Big Gulp), 103mm TB, LT, Exhaust, UDP, Tune, DRs
Category submitted for: 9 (only internal mod is cam, think that puts me in category 9)
R/T.......... 0.536
60'............. 1.664
330'........... 4.585
660'........... 6.993
660’ mph... 101.66
1000'.......... 9.052
1320'.......... 10.782
1320’ mph… 129.05
Name of the track: Auto Club Dragway (Fontana, CA)
Weather conditions: 2237 ft DA - https://airdensityonline.com/track-h...ay/2019-09-29/
Timeslip attached. I have video of the run at
, you can see the time on the board (left lane).
phaedrus is offline   Reply With Quote
Old 10-02-2019, 06:29 PM   #1980
laynlo15
Great pass in the vert
Old 10-03-2019, 01:47 AM   #1981
phaedrus
phaedrus's Avatar
Thanks! It was a long and often frustrating process, but finally figured out how to launch the M6 decently and consistently.
Old 10-03-2019, 12:53 PM   #1982
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
What’s your technique?
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 10-03-2019, 01:18 PM   #1983
phaedrus
phaedrus's Avatar
My setup:
- I installed an MSD 2 step rev limiter as I wasn't happy with OEM launch control etc.
- Had the OEM 4,000 RPM Neutral rev limiter removed via tune.
- 28" Drag Radials - 325/50/15 MT ET Street R for me as I did the 15" conversion, but I think you'd get similar results on a 17" wheel. 18 PSI of tire pressure.
My technique:
- Tour mode - very important as it allows for better weight transfer. You could do just the suspension, I set it to tour overall as it allows you to roll on the throttle more gently and not blow the tires off if needed
- Traction control off, left Stabilitrak on (so single button press)
- Set 2 step rev limiter to 4,000 RPM (or the highest RPM your tires/track/torque level allow)
- 2-4 second burnout
- While staged, floor it and let the 2 step work
- Pop the clucth. No slipping at all, just side step it
Old 10-03-2019, 03:16 PM   #1984
JonDaddy82
JonDaddy82's Avatar
That’s awesome! I think a big thing making mine so hard to launch is the stock tune/torque management.
Old 10-03-2019, 03:46 PM   #1985
phaedrus
phaedrus's Avatar
Yeah, it’s pretty much impossible to launch with the stock torque mgmt / tune. The few times I got it to hook, the computer would jump in and cut my nuts off.
Old 10-05-2019, 12:40 AM   #1986
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Tires used on the pass: Hoosier 28x10 slicks & skinnies
Performance Mods (if any): Heads, cam, LT, 95mm tb(non ported), CAI, PIM, E85
Category submitted for: Category #4
R/T..........0.0775
60'.............1.6447
330'...........4.6044
660'...........7.0351
660’ mph...101.31mph
1000'..........9.1141
1320'..........10.8768
1320’ mph…127.88mph
Name of the track:US131 Motorsports park
Date of pass:10/4/19
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 10-06-2019, 04:19 PM   #1987
NewfieZ
Drives: 2019 ZL1 (Ordered)
First time to the track with my 2019 ZL1. 100% Bone Stock. Stock Goodyear.
R/T............0.515
60'............1.699
330'..........4.795
660'..........7.274
660’ mph...100.33mph
2019 ZL1 Mosaic BLK 10spd
2014 GMC Sierra All Terrain 6.2L
2004 SVT Cobra - Port Blower - Pullied - Exhaust - Sold
2000 Camaro SS - 418ci LS - Brian Tooley H/C/I
NewfieZ is offline   Reply With Quote
Old 10-11-2019, 08:35 PM   #1988
Mannon
Drives: 20188 Camaro SS
Update. Everything the same, lower temp and DA was 650ish.
Car is a 2018 SS M6. Pray tuned/ptb/pi. CAI cai. SW long system. E85.
Tires used on the pass: Hoosier slicks
Performance Mods (if any): CAI, PTB, PI, LT, Exhaust, Tune, E85.
Category submitted for: Cat# 3
R/T: .541
60': 1.573
330': 4.625
660': 7.136
660’ mph: 97.31
1000': 9.275
1320': 11.098
1320’ mph: 123.27
Name of the track: Edgewater Motorsports Park
Date of pass: October 4th, 2019
Mannon is offline   Reply With Quote
