07-23-2018, 07:09 AM | #1975 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
It won't run 9s that easily. You know, everyone always thinks it's just soo easy to run 9s. Like you just slap a blower on a car that is running low 11s and it'll hit 9s no questions asked. If it was that easy, then where are all the 9 sec Mustangs at?
07-23-2018, 07:29 AM | #1976 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
1. The track readiness didn't start with the 1LE (2017), it came with the base SS and correctly optioned base models (2016). People seem to forget that the regular old non-1LE SS has all the coolers and 4-piston Brembos, etc. to track all day long straight from the factory. You don't need the 1LE (which folks are calling the track package) option package to track a 6th Gen Camaro. 2. Ford isn't really playing catch up here, they COULD make a track capable GT by simply adding coolers. The Boss 302 was track capable without overheating. But the confusion comes in when they put tires on the car that really only have benefits on the track (and don't grip that well on the street), then don't add the necessary coolers. The car isn't really optimized for street use, and it can't go on the track without heat issues. It's like Jeep offering an off-road package with the best off-road tires, and then telling you you can't take it off road because it will overheat. |
07-23-2018, 07:35 AM | #1977 | |
Drives: GT350R Join Date: Jun 2017
07-23-2018, 07:49 AM | #1978 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
1) You take it to the track anyway and it repeatedly logs over temp, limp mode. 2) You modify the car to add coolers and make it what Ford says it is not. Track capable. Good luck with either scenario if your engine, transmission or differential fails.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - Last edited by hotlap; 07-23-2018 at 08:17 AM. |
07-23-2018, 09:03 AM | #1979 | |
Drives: 2013 GB GT Join Date: Mar 2016
If you want to narrow it down further to just 2018 whipple cars , well Whipple just started shipping a month or two ago. look it will take a good tire(not an NT05R), possibly half shafts although i'm sure its possible on stock ones, a good tune, headers or cat deletes, E85 although it should be doable on a 100+pump tune and maybe seats pulled. FWIW a 2018 has gone 8.70@161 on a turbo already with stock motor and A10...8000rpm shifts. |
07-23-2018, 09:14 AM | #1980 | |||||
Drives: 21 Bronco Join Date: Jun 2012
I would say base SS track capable, 1LE Track car. Quote:
And major props to GM to making sure all of their performance models are up to the task Ford only does that on Ford Performance vehicles(Raptor, 17+ GT350, ST line, RS) Quote:
07-23-2018, 09:18 AM | #1981 | |
2) I don't know of any manufacturer that will warranty a modified car or is legally obligated to. |
07-23-2018, 09:44 AM | #1982 | |
So, I wouldn't be too worried about a voided warranty due to adding some coolers. |
07-23-2018, 09:49 AM | #1983 | ||||
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
7.39 ratio spread and faster upshifts The new 10-speed’s greater overall performance and efficiency are due primarily to its wider 7.39 overall gear ratio spread, which enhances off-the-line performance with a more aggressive first gear ratio than GM’s eight-speed automatic. Smaller steps between the gears also help the engine maintain the optimal speed for maximum power at almost all speeds, especially when exiting a corner on a track. One of the primary reasons the GT has looked so good on video is because they seem to launch so much better than in years past. I would argue that the A10 is helping them do just that. I fully expect the Camaro to benefit from the very same. I'd also like to point to this...the A8 already has the Camaro running a 4.1 in the 0-60. If the A10 makes the GT a sub 4 second car, that means the Camaro will more than likely do so as well. Quote:
VIR: Camaro 1LE - 2:54.8 GT350R - 2:51.8 Willow Springs: 1:28.29 for both cars Motortrend's Figure 8: 1LE - 22.9 GT350R - 23.30 Quote:
Any car, even a track purpose car, can fail after a single lap. Would I say that any car straight off a showroom floor be able to perform flawlessly? No, I would not. That being said, GM specifically warranties the car in stock form for track use. Which means, unless I'm understanding it incorrectly, that the car is built to handle the abuse if driven correctly. I mean, you can overcook any level of brake pad/rotor simply by overdriving the car. Won't matter whether their on a Yugo or a Ferrari. Quote:
07-23-2018, 10:02 AM | #1984 | |
where does that leave the owner in either scenario?
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
07-23-2018, 10:11 AM | #1985 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
2. Well, for one, non-PP cars and PP1 cars a like have overheating issues. In addition, there are also people with the PP2 having overheating issues. So, it will not be an outlier. Some people claim to not have issues and some are able to alleviate their issues... uh-um, I mean, "keep out of limp mode" (so, not alleviated...) with a few little upgrades. The thing is the particular track and the way in which the car is driven will effect fluid/component temperatures. For an OEM-delivered vehicle, if to be "track-able", it needs to be a blanket for 99.99% of drivers, all track scenarios. 3. The ST line is not that competent and "up to the task" (they overheat the brakes via the torque-vectoring system, engine or differential, too). Nor is the RS. The Raptor, in it's "track" environment and the GT350 (TP/2017+/R) are, yes, capable and competent. The Ford GT is a race car. 4. Exactly. At least offer it as an add-on option. If this was done, I may have gone along with a 2019 PP2 in NFG. I've already tracked a Coyote/MT82 car without coolers - I'm not doing that again. I got away with it then, but I wouldn't now. (FYI the Boss cars are not elusive to heat issues either) |
07-23-2018, 10:18 AM | #1986 | |
What I mean is this: You can put a $50 oil cooler, with cool, shiny red and blue -AN lines, but that $50 cooler may have a pressure and/or flow drop significant enough to cause an insufficient lubrication condition during some extensive maneuver and then destroy the engine. You don't simply just add coolers, like you are on Forza 7. You need to logically chose ones in a sufficient specification for your use. |
07-23-2018, 10:20 AM | #1987 | |
Drives: '18 Zl1. '18 GT350. Join Date: Dec 2016
Reminds me of the old Fast N Furious line. Just turn the NOS timer and you'll run 9's. lol. Like doing that will all of a sudden to gain 2 seconds in the 1/4. First, when he adds the Whip, he'll need to do fueling most likely. I think he's on E85 now, so that helps, but he's going to fuel out anyways esp if he wants to run anything other than stock boost. So, he'll need a cam or low side. He's not getting 9's by just adding a Whip. Now, if he does supporting mods to compliment it, then yes, he'll easily hit 9's. Even on those shit tires he has. I see he's gotten down to 11.3 which is pretty good. I must of seen one of his older videos. But let's be clear, just like every Ford guy, it is NOT stock. They keep staying it's stock, but it's not. So, as mentioned, they keep changing the rules on us as it suits their needs. Just tell people your mods and admit that your aren't stock. It's like he has to say he's stock to make his fanboy friends feel better about their purchases. Once we hit the track, it's gonna be click bait time like a muther. Gonna put............stock Zl1 does 9.2 in 1/4. I'll leave the list of mods out and just tell everyone..............."its a stock block". It still has more in it!!!!!!!!!!!! Well no shit. Every car has more in it. smh.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
07-23-2018, 10:35 AM | #1988 | |
2. True, jsut reporting on what I had seen glancing over there. 3. What I meant by "up to the task" is I believe, I could be wrong that the Ford Performance vehicles are warrantied for track use. "Under the all-caps heading "WHAT IS NOT COVERED UNDER THE NEW VEHICLE LIMITED WARRANTY," the 2017 Ford Car and Light Truck Warranty includes "misuse of the vehicle, such as driving over curbs, overloading, racing or using the vehicle as a permanent stationary power source." However, a Ford representative sent us this clarification: "Ford vehicles such as Mustang, GT350, Focus RS, Focus & Fiesta ST and Raptor are designed for spirited driving and will be covered by warranty if the vehicle is operated within the limits and guidelines outlined in the vehicle's owner's guide and warranty manual, including when the vehicle is driven in 'track mode,' a feature that is contained on some vehicles, if it is driven on a track in a manner that is consistent with the guidelines. From Auto Blog 4. Agreed |
