Old 03-13-2021, 02:03 PM   #183
Invertalon
Drives: 2021 2SS
Originally Posted by SSDan View Post
I don't think the later models beyond 2016 and some 2017's were plagued with this but no harm in adding the ground cable just to make sure.
Yeah, I figure it can't hurt for the $20 total in parts... Cable was $19 to my door and the $1 hex head bolt from the hardware store. Cheap insurance
Invertalon is offline   Reply With Quote
Old 03-13-2021, 06:50 PM   #184
Kemo Savy
Drives: Make it a 6 speed in SS trim.
I just installed my Grnd cable yesterday to the Sound Tube bracket. The extra ground should be good for another 10 hp.
Kemo Savy is offline   Reply With Quote
Old 03-13-2021, 06:54 PM   #185
Kemo Savy
I got my 4ga. Cable cut off the roll at 24 Inches at Advance Auto for about 5 or 6 dollars, then spent about another $3 or 4 for the copper tips. I spent about $10 and 15min of time.😁
Old 03-19-2021, 04:55 PM   #186
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Keep in mind if ordering online there is a huge difference between 4GA and 4/0, 4/0 is rated for 500+ amps and is garden hose like. Seeing as its intention is to buck up the OEM ground 6 - 4GA (4 being the larger diameter) would be more than adequate.
Warrior102 is offline   Reply With Quote
Old 03-19-2021, 08:00 PM   #187
Kemo Savy
I got 4Ga. and matching 4 Ga. copper tips.
Old 03-20-2021, 05:56 PM   #188
Johnnyb2016
Drives: 2021 2SS 1LE
Added an extra ground to mine today.
Ran from sound tube mount to the negative post near the headlight
Used 1/0 cable and plated copper ends.
‘21 2SS 1LE
Johnnyb2016 is offline   Reply With Quote
Old 03-20-2021, 06:17 PM   #189
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Nice job! Thanks for sharing and taking the time to post photos.
476 rwhp/440 rwtq (sold)
Old 03-20-2021, 07:56 PM   #190
shaneotool
Drives: 2016 Camaro SS
Thanks to the OP and the rest who have added info to this thread. I bought a 2016 SS last year and had some major slow start problems. Eventually it left me stranded. I bought a new battery and it’s better for now. I knew it was just a matter of time before it came back though.
I got a 27” 0 gauge cable from batterycablesusa and hooked it up today to the sound tube screw similar to TP2SS. I’m hoping this will help some. I’ll check back in after a while with an update.
shaneotool is offline   Reply With Quote
Old 04-06-2021, 04:28 AM   #191
Fox Starwing
Fox Starwing's Avatar
Drives: 2017 Camaro 1SS Nighfall Gray M6
Ever since getting kooks 2" headers, I have been having this hot start issue. Got a new starter after I cooked the first one, and had the shop install a thermal blanket and a custom fabbed aluminum heat shield. It helped, but it still felt like it lugged out a bit after getting gas or sitting a bit. Saw this thread and stuck one of those 1/0 gauge wires from the boat wire place onto my sound tube mount as it was removed with mods done. The difference was noticable even on cold starts. Thanks for sharing this knowledge, it sure is saving me some serious pucker factor on warm starts after getting gas!
2017 1SS M6 nightfall gray metallic, Lingenfelter 378 CID N/A package, MSD atomic airforce intake manifold, 97mm. Throttle body, 2" kooks longtubes, 3" borla S-type catback, big fat tires and everything.
Fox Starwing is offline   Reply With Quote
Old 04-06-2021, 10:42 AM   #192
ctrlz
That looks stock. Nice job!
Bet that cable weighs almost as much as the sound tube!
Old 04-06-2021, 01:44 PM   #193
fxdxron1
Drives: 2016 Camaro 1SS
I drove my car last week, it was 86 degrees came home parked in my garage for 8 minutes and it started right up. I am 100% certain that adding the ground cable to my SS has solved the slow start when hot.
fxdxron1 is offline   Reply With Quote
Old 04-07-2021, 03:53 PM   #194
WHealy
Drives: 21 LT1
For the record, the 5Gen 19" ground wire does not reach from the sound tube mount to the negative post by the headlight.
WHealy is offline   Reply With Quote
Old 04-08-2021, 09:55 AM   #195
fxdxron1
It will fit perfectly to the water pump.
Old 06-04-2021, 10:14 AM   #196
Blobby
Drives: Former Owner '16 Camaro 2LT V6 conv
It appears that most (if not all) the posts on this thread are for the V8. Any tips for the V6? I have occasional scary hot starts and guess I need to do this. Also curious as to why everyone is stopping at the ground wire. That’s only half of the circuit after all. Seems like the hot wire to the starter is just as important.
Blobby is offline   Reply With Quote
