Old 09-23-2021, 02:22 PM   #183
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
Originally Posted by sr71bb View Post
Well I wouldnt run that on the street for any length of time. The tire poke at the top of the front wheel will result in potentially some rock chip damage on the fender no doubt.
I run APEX EC-7 18 x 11 ET27 wheels with a 5MM spacer and even with MICHELIN slicks 30 68 18 , I DONT have tire poke at the top of the wheel.
On the street I run APEX 19 x 10.5 SM-10 ET25 wheels with 305 30 19 tires WITHOUT a front spacer and I dont have tire poke at the top of the wheel.
IMO it is NEVER a good idea to have tire poke at the TOP of the wheel well. I also think running what amounts to be ONE INCH spacer on the front wheel is NOT desirable.
I wonder why so large of a spacer. Perhaps a smaller one would still work, or would the barrel hit the strut or spokes touch the caliper? Hmmm.
Looks really good though.
Dabjbr is offline   Reply With Quote
Old 09-23-2021, 11:43 PM   #184
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Well doing the Math, my ET27 18 x 11 EC7 wheels with a 5MM spacer basically is the same as a wheel with ET22 offset and that clears fine once you grind the front strut bracket.
SO in MY case I could run the SM-10 19 x 11 wheel with the ET35 offset wheel with a 13MM spacer which also is the same as ET22 offset. This then would be a spacer a little over HALF an inch.
I have an SG3 suspension upgrade though and therefore DO NOT have MRC and those MRC struts give you a little LESS room to the inside of the wheel.
With my 5MM spacer, I DO NOT have to run extended studs because I use an extended lugnut that has threads that start INSIDE the lugnut hole of the wheel. With this I can get about 12-13 thread engagement on the STOCK stud. A good rule of thumb is you want at LEAST 10 thread engagement. WITHOUT the extended lugnut and using a 5MM spacer, you can only get 6-7 thread engagement on the stock wheel stud. HENCE the reason for using the extended threaded lugnut.
Again the main issue to me is running the car with tire poke at the TOP of the wheel well regardless of the size of the spacer. It is NEVER a good idea especially on the street. Potentially the top of the tire could come in contact with the body and especially at high speed that would NOT be good.. I know for instance on a section of the track that I road race alot on, I will go airborne on the RIGHT front tire going over a transition section in the track and if I had tire poke, the tire would no doubt compress enough to make contact with the top of the wheel well. At that SPECIFIC point I am probably going over 100MPH.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 11-04-2021, 07:01 PM   #185
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
Such a good color on this SS 1LE and a great fitment with out SM-10 wheel in Anthracite finish.
APEX Wheel Fitment Specs:
  • Front: 19x10" ET20 with 285/35-19
  • Rear: 19x11" ET35 with 305/30-19
  • Tires: Goodyear Eagle F1 super car 3R
Owner's Instagram: @sinister_camaro6
Apex Wheels is offline   Reply With Quote
Old 11-04-2021, 07:10 PM   #186
Apex Wheels
Drives: Camaro Z28
Originally Posted by Bwaahhh View Post
The SM-10s 305 all around is what I want to go with like the shock and red hot above. I would love to connect with those two to see how back rock chips are......
Sorry for the late reply but there aren't issues with chips for a setup like this, any more so than with something that tucks in slightly more. The tire itself would be more of a culprit as the compound would dictate how much it tosses rocks around.
I would agree that particular car could use a bit more camber up front, but there are no issues with the fender lip contacting the tire, even under compression. There's not that much stroke in the strut to get down that far, it would hit the bump stop.
Old 11-11-2021, 12:32 PM   #187
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Any deals on the new 18 inch wheels? and what were the specs again?
Will it limit you on running a wide tire on front or rear?
Old 11-14-2021, 07:14 PM   #188
Canyonero
Canyonero's Avatar
Drives: F-Series Canyonero
I would be interested in a 18 x 10.5 direct fit front for my SS. Any future plans?
Canyonero is offline   Reply With Quote
Old 11-16-2021, 06:07 PM   #189
metalmark_SS1LE
Drives: 2019 Chevrolet Camaro SS 1LE
That's m... the red hot :)
I was getting rock chips anyways - and silly me, I did not do the PPF.
It isn't horrible, but there are SOME for sure. More with the APEX but... having the extra grip is a worthwhile tradeoff to me. I run the 3R and the combo saves me several seconds depending on the track.
I'm running them for track only, with very occasional street drives when I am too lazy to swap back to stock after track days.
I'm not a very active forum guy, but glad to answer questions on Facebook (Mark Ross) or Instagram @metalmark_ST_1LE
metalmark_SS1LE is offline   Reply With Quote
Old 11-16-2021, 06:16 PM   #190
Apex Wheels
Drives: Camaro Z28
The difference in diameter will not affect width options, in fact most people that are running our new 18" lineup run 315 front and 335 rear, compared to the usual 305/325 combo on the 19s. This is mostly due to tire availability.
The Sprint line of forged wheels is available for pre-order now in the Group Buy, while the flow formed SM-10 wheels will be on sale for Black Friday. You can find details for both of those on our website.
Old 11-16-2021, 06:17 PM   #191
Apex Wheels
Drives: Camaro Z28
Hi, unfortunately we do not plan to offer a 10.5" wide wheel for the Camaro as it's pretty redundant with the 10" and 11" offerings.
Old 12-06-2021, 02:56 PM   #192
EK@ID
Drives: 2007 Civic Si, 1994 K20A Integra
Photos from the past 2 weekends
Hey fellas, just had a great weekend at Thunderhill, Sonoma, and Laguna only to come back home to a NASA AZ weekend where I set a TT3 track record. Lots of work but an epic 2 weekends. 19x10.5 ET22 Anthracite wheels with 305/30R19 tires.
EK@ID is offline   Reply With Quote
Old 12-06-2021, 03:12 PM   #193
sr71bb
sr71bb's Avatar
congrats!!
CONGRATS!!! That's EXACTLY what these cars need a square 305 setup. Makes these cars have pretty much NEUTRAL handling not to mention the fact you can prolong tire life with wheel/tire rotation.
I had a guy in a HIGHLY modfied MIATA with power upgrades as well who was a very good driver come up to me this last weekend and said I was the only one he pointed by him the whole weekend in the RED GROUP. He couldnt fanthom the concept of a 3700 pound camaro being faster in the CORNERS that his Miata. I think is was a WTF moment for him but I assured him that it took ALOT of work to get the car set up that way. LOL The car is fairly easy to drive but you have to have a little bit of a Mario Andretti in you to push the car just up to the limit of adhesion with the nannies turned off assuming of course you have slicks and some pretty incredible brakes. I quite frankly am having a hard time staying square in the seat but since this car is also a daily driver I am reluctant to change out to a full blown racing seat.
Retired Cars BELOW:
Old 12-06-2021, 04:06 PM   #194
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
yea im still not sure if i want a square or staggered setup for next year such a hard choice! haha
Old 12-07-2021, 08:43 PM   #195
Smithpw1
Smithpw1's Avatar
Drives: 2020 Camaro SS 1LE
Is this setup just straight ET22's? Any spacer? Camber plates? Love the look and I like the idea of a square setup.
Smithpw1 is offline   Reply With Quote
Old 12-07-2021, 11:17 PM   #196
Aquarius
Aquarius's Avatar
Drives: Rapid Blue 2022 Camaro 1SS
If this is a square set up with 19x10.5" rims, then the common ET used is 22. If you use this, then a 5mm spacer is needed on the front as well as some grinding on the MRC strut. More information is available about all this with just a little bit of poking around. With an ET of 22, the rears have a slight poke, so some people use an ET 35 on the rear to remove the poke. Not a true, 100% square set up with different ETs, but it still uses the same tire on all 4 wheels, and rotations can still be done, but will require dismounting the tires and remounting them on the other side (and a rebalance).
9/9/2021 - 1100 (date of deposit)
10/15/2021 - 2000
11/4/2021 - 3100 Status TPW 11/15
11/9/2021 - 3400 Status TPW 11/15
11/24/2021 - 3800 Status built 11/21/2021
12/2/2021 - 5000 Status
12/13/2021 - 6000 Status
Aquarius is offline   Reply With Quote
