Old 09-22-2017, 11:23 AM   #183
mzdadoc
Drives: 2017 Red Hot Camaro ZL1 A10
In the time it's taking me to post pics I could have done the whole country's TB's. UGH!!!!
mzdadoc is offline   Reply With Quote
Old 09-22-2017, 11:26 AM   #184
mzdadoc
Pics part 2
In the 2nd to last photo I'm holding the connector showing it's back side you can't see. The grey part slides up towards the wires to unlock it.
The last photo just shows the tools needed and used. A 10mm and a flat blade screw driver. It's not exactly 10mm I know but I work for Toyota so my tools are metric.
Old 09-22-2017, 11:28 AM   #185
mzdadoc
So my review...... Worth every penny!!!!!! Not my first Chevy product and they all had that nothing happens pedal. Now just tap it and she moves!
Hope the pics are appreciated!
Old 09-22-2017, 12:13 PM   #186
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Very much so. Thanks man!
Old 09-22-2017, 12:23 PM   #187
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Ok will someone explain how to post images while I go test drive and fill up my tank?
I've never posted images to a forum before
1. save the image to your local machine.
2. create a post and use "go advanced" feature.
3. click the paperclip -> choose file -> upload.
looks like you figured it out...
Old 09-22-2017, 09:55 PM   #188
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
good job, thanks
speedraider is offline   Reply With Quote
Old 09-23-2017, 10:40 AM   #189
Seventh Camaro
Seventh Camaro's Avatar
Drives: 2022 Camaro 2SS
Does anyone happen to have the torque specs for the throttle body bolts? I am the king of over tightening.
I did ask this question in another thread. Have searched all over and cannot find them.
Appreciate any responses.
Seventh Camaro is offline   Reply With Quote
Old 09-23-2017, 10:46 AM   #190
BSR-1
BSR-1's Avatar
Drives: 17 ZL1 M6 Black
Google search for torque spec on 10mm bolt says 15-22ftlbs but that seems excessive to me. They are not very tight from the factory.
I'd say just snugged + a little (9ftlbs?)
BSR-1 is offline   Reply With Quote
Old 09-23-2017, 10:48 AM   #191
jreagle56
jreagle56's Avatar
Drives: 2022 2SS A10 NPP MRC Red Hot
service manual table shows 89 lb in = 7.4 lb ft
[SIGPIC][/SIGPIC]
jreagle56 is offline   Reply With Quote
Old 09-23-2017, 10:52 AM   #192
BSR-1
BSR-1's Avatar
Even better!
Old 09-23-2017, 10:57 AM   #193
bucknut2006
Drives: 2017 ZL1 A10, 2015 C7 Z51
Had mine on the car for over a week now and I honestly can't tell a difference. Tried all drive modes, did a 1/2 mile race and it seems more of a placebo effect. Tempted to switch back to see if anything changes.
2017 Camaro ZL1 - Nightfall Gray Metallic - A10 - Roto-Fab intake
bucknut2006 is offline   Reply With Quote
Old 09-23-2017, 11:01 AM   #194
Seventh Camaro
Thanks for the quick response!
Old 09-24-2017, 12:44 PM   #195
Dethsupp0rt
Drives: None
I challenge thee for the crown. I snapped one off on another car before . . . luckily managed to use a reverse drill bit and get it out without taking everything apart. Got mocked because I'm an engineer (but not THAT kind of engineer).
But yeah, 89 in-lbs.
Dethsupp0rt is offline   Reply With Quote
Old 09-24-2017, 01:23 PM   #196
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
$ back guarantee.
