Old 08-09-2017, 04:24 PM   #183
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Decided to trade wife's Pathfinder for this (2017 Ram 1500 Sport V8 4x4) so that I will be able to tow when I need it.
glamcem is offline   Reply With Quote
Old 08-11-2017, 09:59 PM   #184
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | DenaliHD | E92M3
You got it! Awesome!
'17 SS 1LE - 1LAP 1LE (Now with more 447!)
'24 Denali Ultimate 3500 DRW
'22 Kia EV6 First Edition
'12 E93 M3
'25 911 (ordered)
Formers...
'18 RS3 (1 of 2) Cumulus Blue | '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 08-12-2017, 05:06 PM   #185
glamcem
glamcem's Avatar
Thanks, I will see if I can tow the 1LE to the ORP for the August 26th event
Old 08-18-2017, 12:58 PM   #186
glamcem
glamcem's Avatar
Installed the ZL1 1LE third brake light. It looks a lot better than tint option for sure
I've also test fitted the track wheels/tires in the car. It's a tight fit but should work if I need to carry them in the car
Old 08-18-2017, 01:35 PM   #187
slick3
Drives: Garnet Red - 20 ZLE
Cem, Were you able to fit the 325 in the rear or is that the 305 in the trunk? I take it you went through the back seat... If only I could leave the canopy, table and e85 and the girlfriend at home, I would be able to pull this off
slick3 is offline   Reply With Quote
Old 08-18-2017, 04:10 PM   #188
glamcem
glamcem's Avatar
I didn't try fitting the 325s. This is the Pirelli DH slick set that I plan to take it to track days and those are 295/305 on 19x10.5"/19x11" wheels. I have been using the NT01s for track days and driving around town
Old 08-18-2017, 04:12 PM   #189
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Which tire blankets did you get? Been thinking about picking up a set.
Eric SS is offline   Reply With Quote
Old 08-18-2017, 04:14 PM   #190
glamcem
glamcem's Avatar
I love these bags
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-22-2017, 07:30 PM   #191
cdb95z28
cdb95z28's Avatar
Glam, I tried a google search, no luck, but what is the thickness of the OE Gen 6 1LE front rotor? 32mm? I was thinking your DBA rotor upgrade may work with my ZL1 front 2 piece rotor on my Gen 5 1LE. I too am runing the ST43's and the cracks on my ZL1 2 piece rotors are growing. The Gen 5 ZL1 rotor specs in at 14.6" (371mm) and 1.26" thick (32mm). Thanks
"KEEP THE FAITH"-Fbodfather
Old 08-23-2017, 12:50 AM   #192
glamcem
glamcem's Avatar
I found this regarding to the front rotor sizes :
Chevrolet Performance Brembo front brake system featuring six-piston monoblock aluminum calipers with performance brake pads and two-piece, 14.6" x 1.3" (370mm x 34mm) vented and slotted Duralife rotors (cast-iron braking rings with aluminum hats).
Those are also the rotor sizes of the C7 Z06 with a different hat design of course.
If I remember correctly, CTS-V, ATS-V, previous gen ZL1 and the new 1LE (and the new SS with 6 piston brembo upgrade) all use the same calipers and rotors/hats so it should most probably work just fine. Don't take my word though, you may want to cross reference the OEM part numbers and make sure those are the same size.
Old 08-23-2017, 11:25 AM   #193
cdb95z28
cdb95z28's Avatar
Thank You!
Old 08-23-2017, 12:52 PM   #194
X25
X25's Avatar
Drives: '16 C7 Z51
As far as I know, BOTH Gen5 and 6 rotors are 34mm thick. Going back to your question, DBAs should work since the hat interface is identical, as long as you use your own hats.
Actually, the story behind glamcem using these rotors is that we had the DBAs for my Corvette, and realized they should work for 5/6th gen Camaro, too, looking at the dimensions, and we let KNS Brakes know about it as well, once verified. C7 Z06, gen 5 ZL1, gen 6 1LE all use the same caliper, with minor differences.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 08-23-2017, 01:08 PM   #195
glamcem
glamcem's Avatar
Thank You!
Sure!
Thanks for the clarification.
It's good to see you on this board, maybe someday...who knows
Old 08-23-2017, 02:23 PM   #196
cdb95z28
cdb95z28's Avatar
Originally Posted by glamcem View Post
Sure!
You can add CTS-V to that also on the caliper crossover. Previous generation, not sure about the current.
Yeah, X25, surprise to see you pop in here, lol
Thanks fellas!
